  #11
Old 11-12-2009, 12:57 PM
Dean_aeroleds's Avatar
Dean_aeroleds Dean_aeroleds is offline
Just an update on AirPlan. I have located a source of navigation data and plan on making database updates available soon. I will have to charge a small amount per update ($10) to cover the expense of buying the data and hosting the Razor's Edge website, but considering that the software is now freeware that is a pretty good deal.
I will post another message on here as soon as I have the database update available.
Dean Wilkinson
Old 11-12-2009, 04:22 PM
GrayHawk's Avatar
GrayHawk GrayHawk is offline
I don't seem to be able to run Airplan (prior paid subscriber) on Vista 64, even as Administrator.
But that's OK as I think I'll revert to 32 bit.
GrayHawk
My rebuild log: http://www.cherryfamily.net/bill/n63tx/rebuild/
Texas Hill Country Hangar For Sale: http://www.myspicewoodhangar.com/default.htm
Old 11-13-2009, 07:16 AM
N282S's Avatar
N282S N282S is offline
Dean Wilkinson
Thanks for the updates. I got ten dollars!
Steve
registered user
Old 11-20-2010, 02:59 PM
To all users of my freeware flight planning software, AirPlan, I just posted database updates for the airport and navaids on the website:
http://www.razorsedgesoft.com
In case you aren't aware of this FREE flight planner, here is a screenshot:
Old 05-30-2011, 11:42 AM
Updated Airspace, Airport, Airway, VOR, NDB, Ostacle, and Waypoint database files are now available for AirPlan that are from the current update cycle. I plan on making database updates available from now on since I have found sources for all of the U.S. data now.
If I get enough support, I will also start making Sectional and WAC charts available for AirPlan.
If you have Vista or Windows 7, I recommend that you run AirPlan in Windows 95 emulation mode (set the properties for AirPlan.exe) as Administrator. Otherwise, it may have trouble running.
Old 05-30-2011, 12:31 PM
Pilottonny Pilottonny is offline
Default Europe?
Only USA, I assume?
Regards, Tonny
"Pilottonny"
Tonny Tromp
Lanaken, Belgium (EU)
RV9A, Registration: PH-VAN
ECI-Titan IOX-320 with dual EI, turning a Whirlwind 200RV CS prop.
Sold
Old 05-30-2011, 04:39 PM
Ron Lee's Avatar
Ron Lee Ron Lee is offline
I just got the program and paid for a database update but cannot find the method to get the update.
Update on update: Completed!
Old 05-30-2011, 06:36 PM
Originally Posted by Pilottonny View Post
Only USA, I assume?
Regards, Tonny
Yes, only the USA, the data comes from the FAA. AirPlan used to cover the entire earth, but then the U.S. NIMA agency removed the DAFIF from public access. It was a good thing while it lasted. At least we still have U.S. data sources that aren't from Jeppesen.
Dean
Old 06-01-2011, 09:33 AM
Ron, I sent you an email with the download link...
Dean
