05-29-2011, 09:59 AM
Compressor installation question
For those of you who have larger compressors, say 60 gal and up, here's a question. They all seem to have either 3 or 4 legs with mounting holes on each. I'm told by the sales guy that you don't want to leave it and operate it on the wood pallet it came on. Which means I either need to drill holes in my garage floor and bolt it down, or something else. What are other viable alternatives, if any, other than bolting it to the garage/shop floor? Photos would be helpful.
05-29-2011, 10:13 AM
Mine sets on small wood blocks with rubber on top and bottom. Not anchored down. Been working fine that way for over 20 years.
2-stage compressor, 80 gallon vertical tank. Plumbed to the wall through flex a line.
RV-6 Flying since 1993 (sold)
<rvmel(at)icloud.com>
05-29-2011, 10:39 AM
Yes, that's the type of installation I'm interested in. Does the vibration cause it to move across the floor at all? What size blocks and what type of rubber material are you talking about? Thanks Mel.
05-29-2011, 10:42 AM
Mine is set up just like Mel's. Take a look here, the last pic shows the block under a leg. It's cut just bigger that the foot. I used a cut up old mouse pad under the wood. It doesn't move at all. Good luck and have fun!
Kobwo
Having to get out of the building business
05-29-2011, 10:48 AM
The blocks are about 4" square, 1" thick. The rubber is pretty hard, about 1/4" thick. Compressor does not move. It did move once from Plano to Farmersville, but not on a daily basis.
05-29-2011, 10:57 AM
Mine's been bolted to the wooden pallet it came on for the last 8 years. Never moved an inch while running. Of course, being in the military I move every 3 years, so bolting it to the floor isn't a good option for me. Leaving it on the pallet has made it easy to move with a hand-truck.
PJ Seipel
RV-10 #40032
05-29-2011, 11:04 AM
Senior Curmudgeon
Carpet....
Mike Starkey
VAF 909
Rv-10, N210LM.
Flying as of 12/4/2010
Phase 1 done, 2/4/2011
05-29-2011, 11:54 AM
Rubber door mat.
Hendrik
Club-Libelle: flying
RV-8: on hold (new job  , new home  , no workshop (yet)  )
05-29-2011, 12:12 PM
80 gallon
Three legs, bolted directly to the concrete floor with 1/2" bolts. I thought of rubber hockey pucks as an insulator, but went with simple.
The beauty of a larger capacity compressor is that it only turns on once or twice per session. Unless I'm using the disc grinder.
Lorne
RV 7a tip-up
Pre-cover MD-RA Inspected.
05-29-2011, 12:24 PM
been here awhile
Mine (60 gal, Home Depot) is still bolted to the wooden pallet, been good for several years now. I think the pallet is fine as long as it doesn't deteriorate enough to allow the compressor to tip over.
