Old 05-26-2011, 11:47 AM
Roo747's Avatar
Roo747 Roo747 is offline
Default Garmin G3X ADAHRS question
Hey Gang,
Looking into EFIS for and upcoming (just started) RV8 and had a question regarding the GPS aided ADAHRS that garmin advertises.
Does anyone know what happens if the GPS signal fails?
Andrew
Old 05-26-2011, 12:13 PM
Ironflight's Avatar
VAF Moderator / Line Boy
According to the Pilot's Guide (there is a drawing in the System Overview section), it will do just fine as an Attitude/Air Data platform with Magnetometer and Air Data only.
If I read the drawing correctly, of course.
Paul
Paul F. Dye
RV-8 - N188PD - "Valkyrie"
RV-3B - N13PL - "Tsamsiyu"
Dayton Valley Airpark (A34)
http://Ironflight.com
Old 05-26-2011, 01:19 PM
mburch's Avatar
mburch mburch is offline
Check out section 10.5.1 of the G3X install manual, and/or page 18 of the G3X Pilot's Guide - that should have all the data you're after.
cheers,
mcb
Matt Burch
RV-7 (last 90%)
http://www.rv7blog.com
VAF #836
Any opinions expressed in this message are my own and not those of my employer.
Old 05-27-2011, 07:44 AM
Sig600 Sig600 is offline
Short answer, it'll still tell you correct attitude information, you just won't have 2D/3D position information.
i.e. you'll know which way is up, but you'll have to navigate the old fashion way.
Next?, TBD
IAR-823, SOLD
RV-8, SOLD
RV-7, SOLD
Old 05-27-2011, 05:08 PM
rjtjrt rjtjrt is offline
I hope I'm not asking an obvious question (I did run a search).
What happens to attitude information on G3X if pitot blocked?
John
Old 05-27-2011, 05:31 PM
Attitude is derived from solid state. Pitot/static info remains the same, it just all runs through the same magic box. Think old school steam gauges, but solid state instead of a vacuum and gyro.
Next?, TBD
IAR-823, SOLD
RV-8, SOLD
RV-7, SOLD
