Eng mount cracking
I've herd this is a common problem, the guy who built my RV-6 had the eng removed and the eng mount removed to CO a mod the repair and stiffen the lower corners around the gear leg mounts, I'm in the middle of rebuilding the aircraft, when I inspected the eng mount I too found cracking at the lower corners adjacent to the gear mount tubes.
Hope this helps..
Nick Purcell
Licensed on B767, A330 Eng/Airframe
Fixing up RV6, building a Stewart S51
Basically a major overhaul of everything.
