interesting read, thank you. Now i have the spark plug gap too, excellent.
So, what I figured is the cross plug for the 24emrc is the ngk br8ecm. These plugs are shorter. I may have a little less space than some because my engine has it's own enclosure. the longer would probably fit but I'll stick with the short.
So I'm going to go with the ngk because their local here and run around the same price. Please if anyone thinks the quality is better in the denso, or it will work better for my app then certainly tell me and I'll go with denso. Otherwise I would have kind of thought myself that the ngk should run at least equal. GTG?
Harmon Rocket II "the rockin bird"
