05-13-2011, 06:43 AM
Originally Posted by 1911pilot
Just out of curiosity why don't you want to cut within 3 inches of the canopy frame?
Not exactly sure, but probably to keep you away from that gas tube running along the edge. I don't have F-35 time though.
05-13-2011, 07:18 AM
VAF Moderator / Line Boy
Stratosphere, Here We Come!
Originally Posted by WillyEyeBall;541867I can't think of any fighter more sexy than a F 104 with the tip over canopy:
[url
http://www.google.com/search?q=f+104&hl=en&prmd=ivns&tbm=isch&tbo=u&sour ce=univ&sa=X&ei=jyDNTa-uIoiCtgeq9YzsDQ&sqi=2&ved=0CDIQsAQ&biw=1028&bih=62 8[/url]
and wish mine tipped too, sometimes.
Bill McLean
RV-4 Slider
Thanks for reminding me of that! I feel much better about the RV-3 tip-over now - great heritage.
Guess I need to start looking for a rocket motor for "Junior's" tail to turn it into an "N" model....
Paul F. Dye
RV-8 - N188PD - "Valkyrie"
RV-3B - N13PL - "Tsamsiyu"
Dayton Valley Airpark (A34)
http://Ironflight.com
05-13-2011, 07:52 AM
Super Moderator
Location: Hangar/home at Hicks Airfield (T67), Fort Worth, TX
F35 Canopy
Originally Posted by Cooperd0g
I doubt it is det cord. Det cord is usually in a zig zag pattern on the very top a-la the T-45 and the AV-8B. That tube is mostly likely a gas tube to provide pressure to the canopy seal and/or jettison system.
Guess again, the canopy does not jettison. The seat goes thru the opening made by that "det cord", or whatever you want to call it. Question, where did you come up with that photo of the F35 indoors?
Mike Reddick
VAF#153
Pilots N Paws Pilot
RV6A N167CW 1,900 HRS
Ft Worth, TX (T67)
05-13-2011, 08:30 AM
T-6 Texan II JPATS
Paul,
While it's not a fighter, the T-6 Texan II has a tip over canopy design. I'd fly it in a heartbeat! Bunch of my friends have plenty of time flying NFOs in P-cola around in these things. What a blast!
RV-8 empennage DONE
Wings 99% done
Fuselage in progress
05-13-2011, 09:17 AM
I think I found the pictures on CodeOne.com or something like that. I'm not that familiar with the jet so it is surprising to hear that the canopy doesn't jettison. That tubing still doesn't look like det cord though.
05-13-2011, 10:14 AM
canopy design - thickness etc.
...sounds like we have some F35 experts here.....so is it possible ( unlike the F16) that the 'one-piece' tip up actually has a thicker windscreen for bird strike etc., or heat, HUD requirements?, and the rest of the canopy aft of the bow is a different thickness or material?
just curious...
Perry Y.
RV-9a - SOLD!....
Lake Country, BC
05-13-2011, 10:41 AM
Originally Posted by sprucemoose
This is true, and for the 0.05% of the time you spend in your airplane in this condition, the slider has the advantage. In the other 99.95%, the tip-up wins in every category.
To the OP- you really need to sit in, and fly, both types. You shouldn't have any trouble tracking down an example of each.
Concur with Jeff...gotta try both. So when you come out to check on baggage areas for dog-carrying capacities (from that other thread), you can sit in a copy of each...and if the wind is down, probably won't take much arm-twisiting to go flying!
The tipper might win on dog-entry procedures too. For dogs (or people), its just a different feel...ducking below the canopy or swinging in. Both work great, and again, its a small percentage of the flying envelope.
I have a slider and like it, but flew a tipper 9 yesterday. The vis is awesome, that's for sure. Might be tougher to see the bogey behind you...but then again, that would never happen, now would it!  I'll just use my canopy bow to tell how many degrees angle off of your tail I am!
Originally Posted by DanH
Consider this snippet from Raymer's "Aircraft Design..":
That elbow-on-the-sill cool factor stuff kinda evaporates when you get passed.....
Ouch!  Good thing many/most of the F1s have a slider, or I'd never be in the race with them!
Truth hurts tho, don't it!
Bob
05-13-2011, 12:02 PM
Super Moderator
But it is, no jettisonable canopy!
Mike Reddick
VAF#153
Pilots N Paws Pilot
Ft Worth, TX (T67)
05-13-2011, 03:15 PM
Sight reference
[snip]F-16: It also has a tip up canopy that goes backwards, but there is no canopy bow support as the entire canopy goes up. So it is more like the RV tip up in that regard. Man visibility is incredible! But you lose the sight references from the Hornet.[snip]
That problem, if it really is a problem, can be solved very easily so that you get the best of both worlds. Go with the F-16 / RV tip up style canopy, and paint or tape a thin line on it, if you find that useful as a sight reference. This really is the best of both worlds in that you can have your sight reference, but unlike a structural canopy bow, you can make the line very thin so that it doesn't obstruct your field of view.
05-13-2011, 05:35 PM
Another great tip-over not yet mentioned.....Bf 109.
And then there is the RV-4
Glenn Wilkinson
_____________________________________________
RV-4 Sold
N654RV @ MLJ
RV-7 Coming Soon
N987RV Reserved
2015 Donation Gladly Paid
"Maintain Thy Airspeed, Lest the Earth Arise and Smite Thee"
