Old 05-18-2005, 12:12 PM
f1rocket's Avatar
f1rocket f1rocket is offline
Default Tip: Rudder Cable Exit Fairings
Some folks will look at this as a lot of extra work for nothing. I don't disagree. But there are some builders that just can't stand to see the plastic tubing for the rudder cables sticking out into the wind. I just happen to be one of those builders. Here's how I handled it.
I have seen them just riveted to the outside of the fuselage and also just riveted flush. I thought about this but I couldn't find a way to remove the rudder cables after assembly. The swaged end of the cable will not fit through the opening in the fairing. So I will attach mine with some #4 screws. I don't foresee a reason to ever remove the cables, but it would be just my luck that I would someday.
I ordered a package of cable fairings from Avery. You get three of them in a package. The first step is to trim them to the desired size. I left an even area all the way around, just enough for the mounting screws. Be sure to mark a left and a right one when your done.
Next I cut holes in the side of my fuselage using the fairing as a guide. That's why it is important to mark both a left and a right fairing so the holes will match each part closely. I used some scrap to fabricate a reinforcing ring. In the middle of the ring I cut a slot for the plastic cable tubing. The slot ends just a little short of the end of the fairing so that the plastic tubing will be squeezed by the fairing when it is screwed in place.
After a bunch of drilling and riveting, I screwed the fairing to the reinforcing ring. I then positioned the ring in the skin opening so that I could center the fairing in the opening evenly. I then drilled the attach holes through the skin and ring. After cleaning and dimpling, I riveted the ring in place.
On the inside, all that was left was to make an attachment for the -6 hose clamp to secure the end of the plastic tubing. I made a couple of L brackets from scrap and riveted them to the longeron. I used a nut and bolt to hold the clamp to the bracket.
When I was all done, this is what it looked like. Now I like that much better than just a slot.
Randy Pflanzer
Greenwood, IN
www.pflanzer-aviation.com
Paid through 2043!
Lund fishing Boat, 2017, GONE FISHING
RV-12 - Completed 2014, Sold
427 Shelby Cobra - Completed 2012, Sold
F1 EVO - partially completed, Sold
F1 Rocket - Completed 2005, Sold
RV-7A - Partially completed, Sold
RV-6 - Completed 2000, Sold
Long-EZ - Completed 1987, Sold
Old 05-12-2011, 08:35 PM
fehdxl fehdxl is offline
Randy, Are you still doing it this way... 8-1/2 years later? Or have you come up with a better way? Thanks! -Jim
Old 05-12-2011, 08:45 PM
mike647m mike647m is offline
I just used proseal. They look great!
Old 05-12-2011, 08:55 PM
Mike, Just stuck to the outside? Or did you make the hole in the skin bigger and stick it to the inside? Pictures? ...maybe I need to start a new thread... Thx. -Jim
Old 05-13-2011, 05:34 AM
Rick6a's Avatar
Rick6a Rick6a is offline
Default Stick it
I just used proseal........
Attached with proseal only, the rudder cable fairings on my -8 are not going anywhere. To assure a proper bond, adequate surface prep recommended. Using no rivets or screws for traditional attachment, the simple technique eliminates the chance of moisture potentially gaining a toehold between the fairing and the skin.
Rick Galati
RV6A N307R"Darla!"
RV-8 N308R "LuLu"
EAA Technical Counselor
Old 05-13-2011, 09:56 PM
Yes, like Rick says
