Old 05-09-2011, 09:36 AM
Airhead Airhead is offline
Default Firewall forward ground block
I see many references on builders' sites and this forum regarding a multi tab grounding block on the engine side of the firewall, sometimes mounting a block with 12, 24, or even 36 tabs such as those sold by B & C. I am going to use an EMS (Dynon, if it makes any difference) to monitor all engine parameters. In looking over the installation manual I can find no reference to ground connections forward of the firewall.
My question: Can anyone with the same or similar EMS installed shed some light on what FWF ground connections they needed? I am thinking that the need for this large array of grounding tabs may be based on more traditional engine instrumentation.
Bob B
RV-7A QB slider - IO 360 M1B Hartzell C/S prop w/Dual 10" Dynon Skyviews - Classic Aero interior. Florida (SFB) based. 170 hrs TT .
Old 05-09-2011, 09:42 AM
RV10Rob's Avatar
RV10Rob RV10Rob is offline
I installed a "forest of tabs" ground block on both sides of the firewall, and until last weekend had nothing connected to the forward side. The hall effect RPM sensor I just installed needs a ground, so now I have one. With a standard Dynon setup, you shouldn't need one.
-Rob
Rob Kochman
RV-10, Flying as of March 2011 (blog)
Paine Field (KPAE)
EAA Chapter 1440
Old 05-09-2011, 09:44 AM
647jc's Avatar
647jc 647jc is offline
For my Dynon installation I did not find a need for a comman grounding block FWF. Most of the sensors either ground to the engine block or have a seperate ground lead going back to the Dynon EMS.
Joe Condon
Ankeny, Iowa
RV9A - 647JC - 300 hrs - SOLD 6/23/15
OneX - Under Construction - For Sale
Old 05-09-2011, 09:45 AM
Mike S's Avatar
Mike S Mike S is offline
Senior Curmudgeon
I agree, there is no need for a lot of ground tabs f/f.
As I recall, I only grounded the tach sender and the solenoid diodes, and those times I used the mounting bolt for the device.
Other than these, there is the main ground strap to carry the starter load, but it does not go to a faston tab.
Good luck.
Mike Starkey
VAF 909
Rv-10, N210LM.
Flying as of 12/4/2010
Phase 1 done, 2/4/2011
Old 05-09-2011, 09:49 AM
lostpilot28's Avatar
lostpilot28 lostpilot28 is offline
Hi Bob,
I don't use any of Dynon's products, but I wanted to point out that "ground is ground", regardless of whether it's forward of the firewall or aft. The reason a lot of builders (including myself) go with a ground buss (plate with tabs) is that it helps prevent ground-loops (No, not the tail-wheel kind).
Regardless of what EMS or EFIS system you go with, you would do well to have a centralized location for your grounds. Even though it's extra weight to run each ground wire back to the buss, I found that it prevents a lot of headaches. I'm completely guessing, but that extra weight was probably less than 1 pound.
Sonny W
Boise, Idaho
RV-7A Flying!
Old 05-09-2011, 09:56 AM
Thanks for the quick responses guys. I was going to mount a multi tab ground block on the aft side of the firewall (for avionics ect.) co-located with the battery grounding strap bolt, and based on the replys so far, it seems like this would suffice.
Bob B
Old 05-09-2011, 10:04 AM
Greg Arehart's Avatar
Bob,
For my ground, I used a piece of 3/16" threaded brass that goes through a hole in the firewall with a washer and nut on either side. I made it long enough that all my grounds (either side of firewall) go onto the "ground bolt" with multiple brass washers and nuts. This is grounded directly to the battery with a heavy copper strap. I used crimped rings rather than faston connectors.
greg
Greg Arehart
N 7965A
