Old 05-05-2011, 05:22 PM
datsclark datsclark is offline
Default gas tank inspection port -- problem?
For various reasons (read: i messed up) I managed to drill the inspection cover slightly off center from the large hole. These pictures should explain what i mean (I realize it is cleco'd together backwards):
The tooling hole is now no where near covered by the backing plate. I feel like this is all a pretty minor issue all things said and done, but i'm not sure.
Should I build-on or does this need some kind of attention?
RV7A/TU Finishing Kit
Old 05-05-2011, 08:27 PM
zilik's Avatar
zilik zilik is offline
VAF Moderator
I would keep building. I might drill out the tooling hole and install a mega rivet or AN bolt instead of relying on proseal to fill the hole. Nobody but you will ever know and someday you'll forget about it.
Gary "Seismo" Zilik
Pine Junction, Colorado
RV-6A N99PZ S/N 22993 SOLD
Old 05-06-2011, 05:09 AM
bhester's Avatar
bhester bhester is offline
Thumbs up Not a problem!
Just proseal that tooling hole both inside and out. If you want to put a rivet in there use a countersunk rivet flat on the out side and notch the support ring on the inside to allow clearance.
Bobby Hester - Builder/Pilot/A&P
Surfing the web from Hopkinsville, KY
N857BH RV7A XP-O360 - Garmin G3X ADS-B IN/OUT 2020 Compliant
Web site: http://www.newtech.com/bobbyhester/RVSite.htm
Dec. 2019 VAF donator - alot better than any magazine subscription
Old 05-06-2011, 01:30 PM
Thanks guys. I'll just build on. Just another part to make my plane unique!
