Old 05-04-2011, 03:04 PM
SuperCubDriver SuperCubDriver is offline
Default Rivet gun oiling
I?m having a 3x Rivet Gun. It came without any instructions or manual. Should I oil the gun now and then? Or how often?
Old 05-04-2011, 03:07 PM
Hens07's Avatar
Hens07 Hens07 is offline
I put 1-2 drops in the air intake before I use it (only once a day). I know some people that only oil it 1-2 times a month however....
Andrew
Lancaster, PA l RV-7 #3898 l Empennage l N627AB
"I fly because it releases my mind from the tyranny of petty things" ~Antoine de Saint-Exupery
Old 05-04-2011, 03:17 PM
RV7Ron's Avatar
RV7Ron RV7Ron is offline
It depends on how much use your tools are getting. I do three drops about once a week, which seems sufficient. An in-line oiler is another option....although if you go that route, you will need a seperate, oil-free, hose for painting/priming.
Ron Duren
Mechanical Engineer
"SportAir PhD"-RV Assembly/Composites/Electrical
Denver, CO (KBJC)
RV-7 'Tip Up'
Flying!! as of 3/16/14
IO-375/WW 200G-CS/SkyView/Dual P-mags
N531R "Wablosa" Wings of Red
http://www.ronsrv7project.blogspot.com
