05-02-2011, 10:03 PM
stall warning device holes
Any suggestions for filling the leading edge holes left by not installing the stall warning device?
05-02-2011, 11:28 PM
Rivet
Dimple skin and install flush rivets. I used C-frame and small diameter set. Align the skin and rivet carefully in the C-frame and smack a few times with a hammer. Looks good to me.
05-03-2011, 07:01 AM
Same here...works fine.
Ron Duren
Mechanical Engineer
"SportAir PhD"-RV Assembly/Composites/Electrical
Denver, CO (KBJC)
RV-7 'Tip Up'
Flying!! as of 3/16/14
IO-375/ WW 200G-CS/ SkyView/ Dual P-mags
N531R "Wablosa" Wings of Red
http://www.ronsrv7project.blogspot.com
05-03-2011, 08:59 AM
Easy
I just used the blind rivet dimple die and then bucked the rivets with very light pressure. I also had no ribs installed and stood the skin up on end so I could get to the inside curve easier.
Pics: http://websites.expercraft.com/sblai...y&log_id=57567
Piece of cake.
05-03-2011, 09:51 AM
see this thread
http://www.vansairforce.com/communit...ad.php?t=71738
Guys, not trying to be a pr...k or anything, just illustrating a point - I assume that the reason that you are not installing the stall warning device in the holes is because you have an alternate (better) stall warning - AOA, EFIS or other??
Gary Reed
RV-6 IO-360
WW 200 RV now an Al Hartzell for improved CG
05-03-2011, 10:14 AM
Definitely a good question/point (although it my be a little OT for this thread?). I plan to use an AOA/EFIS system, that was my decision behind not installing the stall warner from Van's. Some guys do both...but I agree, some kind of stall warner system should be installed IMHO.
Ron Duren
Mechanical Engineer
Denver, CO (KBJC)
RV-7 'Tip Up'
05-03-2011, 10:24 AM
Thanks and sorry Ron
and again, not trying to be a pr..k or a snitch. Just thought it was a timely co-incidence that your innocent thread got started right in the middle of all of these other thorny threads. Could'nt pass it up!
Gary Reed
RV-6 IO-360
05-03-2011, 10:46 AM
no problem at all, I dont mind the question one bit. I know what you're saying, things are a little 'heated' on the ol' forums at the moment, to say the least.
Ron Duren
Mechanical Engineer
Denver, CO (KBJC)
RV-7 'Tip Up'
05-03-2011, 12:52 PM
AFS AOA instead
An AOA instrument was one of the first things I bought for my plane-to-be (thanks VAF forum). I didn't know the kit came with a stall warner. Decided I didn't need both.
11-13-2014, 01:38 PM
I am using the Dynon AOA system, so what I have done is scuffed up the inside and put a line of fine glass on the inside.
Will then fill from outside.
Didn't want to dimple and rivet as there is no support behind the skin to prevent denting.
"I add a little excitement, a little spice to your lives, and all you do is complain!" - Q
Donated in 2020
