Old 04-25-2011, 06:55 AM
mike in phx mike in phx is offline
hey kevin lots of changes from when you flew the plane it was very solid when you where here.
And it has only been going in the rigth direction
but the intercooler exit is still the same it was the big buble on the buttom cowl that i removed.
now it looks like an Rv as you know i have a lot of cleanup to do on the aerodynamics. pictures are comming.
How are things with you ?
Mike Poulsen
Phoenix
RV 6 TURBO
N 694 MP
Old 04-30-2011, 07:45 PM
Default cowling
ok as promised pictures of a ruff cowl before and after.
these 2 pictures is before turbo lots of drag
and these are with turbo and redused cowl exit aka the Dan H mod
and here is a couple of pics of a stock scoup on top of my exit and then the differens
Mike Poulsen
Phoenix
RV 6 TURBO
N 694 MP
Old 05-01-2011, 03:45 PM
Default oil temp
trying to lower my oil temp for some time and i knew i had enough oil cooler but then i saw high numbers and started trying to get the numbers down but nothing helped changing sensor ,more air over oilcoolers litle stuff here and there then this morning i went out and climbed to 11500 in 8 minat 100 knots indicated my oil temp went to 242 F
and then i started flipping switches and it went to 365 F if i turned all on
but if i turned alt field off then it went to 207 F from 242F
turns out if im crusing at 228 F oil temp its only 198-201 F
its fine on the ground not running its fine climbing out but 205 and above its like a bad sensor and its brand new
Mike Poulsen
Phoenix
RV 6 TURBO
N 694 MP
Old 10-30-2011, 04:13 PM
Default @ the anual mark
So after a very busy summer with lots of flying im now ready to do the anual and inspect the turbo system lots of good trips to cali,boneville,this system has been very solid even in the heat of phoenix the hottest day of the year i was comming back from bakersfield with my dad and just to test temp on all components i was at 13500' running 100-102% for 2 hours and all was in the green truing out at 198 knots we had 15-20 knots on the nose and i still had 180-185 knot gs. This has really proven to be a very solid platform wit 93 hours this year it has performed flawlesly i hope everybody else have had a good funfiled summer wit lots of flying
Mike Poulsen
Phoenix
RV 6 TURBO
N 694 MP
Old 10-31-2011, 03:04 PM
turbo's Avatar
turbo turbo is offline
yes we had a great summer. i like your ideas. turbo
TURBO YES =VAF= Payed Jan2019
Ed D'Arcy
addicted pickle ball player
Old 10-31-2011, 07:08 PM
Default Thanks
Thanks turbo are you gona live up to your name soon ??????
Mike Poulsen
Phoenix
RV 6 TURBO
N 694 MP
Old 10-31-2011, 08:36 PM
Snowflake's Avatar
Originally Posted by mike in phx View Post
...i was at 13500' running 100-102% for 2 hours and all was in the green truing out at 198 knots we had 15-20 knots on the nose and i still had 180-185 knot gs.
Just out of curiosity... What was your fuel burn while doing that?
Rob Prior
Old 10-31-2011, 09:43 PM
Fuel burn for that kind of flying is of course high so 11.8 ghr
But thats running on the edge of my comfort zone
Mike Poulsen
Phoenix
RV 6 TURBO
N 694 MP
Old 11-01-2011, 09:35 AM
Bavafa Bavafa is offline
Does one dare to ask how much such upgrade cost
It is impressive though.
Mehrdad
N825SM RV7A - IO360M1B - SOLD
N825MS RV14A - IO390 - Flying
Dues paid
Old 11-01-2011, 07:25 PM
riobison riobison is offline
good question
