04-30-2011, 06:57 PM
Center of lift...
Can someone tell me where the center of lift is on the RV-4? I'm wondering where it is relative to the CG range of 68.7" - 77.4".
Chris Smith
Maule M5-180C (Sold)
RV-6 O-360 CS (Sold)
RV-4 O-360 FP (Sold)
Full-time in the other type of RV....
04-30-2011, 07:28 PM
The center of lift moves around with angle of attack.
The neutral point is fixed and located behind the CG range.
04-30-2011, 07:44 PM
Thanks for the info!
Chris Smith
05-01-2011, 06:42 PM
I've always assumed the center of lift on any wing I'm looking at will be very close to the main spar. Wrong?
Kevin Cameron - Fresno, CA - E79
N493DB RV4 Flying IO-360-A1B, 10:1, Straight-Bore cylinders, Gapless Piston Rings, Hartzell CS Prop,
AFS3400-EE, TruTrac DFII VS, Aera 660, GTX 335, GDL 52R,
XM Radio, SL30, SL40, PMA9000EX, MicroTrac 300 APRS
05-01-2011, 08:41 PM
With respect to the wing alone, the airfoil's AC is at about 24% back from the leading edge. I believe that puts it pretty close to the wing spar. Angle of attack has very little influence on it.
edit: since you asked about where the AC of the airplane is - that's the combined effect of the wing/tail/fuselage/propeller system which is also called the "neutral point". Assuming a 20% static margin (distance from NP to CG expressed as a % of mean aero chord) that would put the CG 12" (20% of 5 feet - the wing MAC) ahead of the neutral point which also is considered the aero center for the airplane. So if your CG is at 70" then the aero center (neutral point) for the airplane would be at 82", as a real rough example.
?The important thing in aeroplanes is that they shall be speedy.?
- Baron Manfred von Richthofen
RV8 under construction
RV4 - Sold
United B777 FO, Chicago
Aero Engineer
RV8
