04-27-2011, 05:05 PM
Slider top skin - how do I set these rivets?
Any idea how to set the two rivets circled? The canopy deck gets in the way such that even my thinnest of bucking bars (1/2") and squeezer yokes (used as bucking bars) are too thick. I managed to get the ones right under the spar cap, but neither of the two aft of it. Because they are 426 3-7 rivets, whatever bucking bar I might use needs to have some mass. I've heard/seen people use pulled rivets here, but since the holes are dimpled for 3/32 and since it has to go through the thick longeron, I'm not sure what I could use. It's been so long since I did any signficant riveting that I've forgot all my tricks!
Any thoughts re: what you did to get these couple of rivets would be appreciated.
Steve M.
Ellensburg WA
RV-9 Flying, 0-320, Catto
Donation reminder: Jan. 2021
04-27-2011, 05:15 PM
back rivet plate
I was able to slip my back rivet plate up there to buck them.
Kelley Kokemiller
9A sb N94KK 400hrs. and counting
Barrett O-320
Catto 3-blade
Panther tail complete
04-27-2011, 05:16 PM
Blind rivets
without seeing the other side and not being familiar with the slider setup I'd say install a couple of 3/32 Csk blind pop rivets, unfortunately I don't have a part No for you but they do exist, i'm sure someone else will have another option or part numbers to help you out. Good luck with it.
Nick Purcell
Licensed on B767, A330 Eng/Airframe
Fixing up RV6, building a Stewart S51
Basically a major overhaul of everything.
04-28-2011, 10:26 AM
I used a 1/4" or 3/8" thick steel bar I had around the shop. It was about 8" long x 2" wide so it had some mass. Notch one corner as required to reach the rivet tail.
Five Sierra Fox
RV-9A
Utah
04-28-2011, 10:56 AM
Cherry Part Number
CR3412-4- is a 1/8 " rivet with a NAS 1097 head that will fit your dimple.
04-28-2011, 12:34 PM
Thanks for all the suggestions. Spruce doesn't seem to carry those CherryMax "oops" rivets, but the back rivet plate method gives me an idea if I can't find them elsewhere.
Steve M.
Ellensburg WA
05-01-2011, 12:44 AM
I think I riveted them using the thinner edge of a tools pry.
RV4 IO-320, Catto 3-blade, Christen, I-BILT
Flight time: 1 hour
Status: test flights
www.rv4.it
ROME, Italy
RV9A O-320 D1A, Hartzell C/S prop, slider, I-PRCA
Flight time: 350 hours
Status: SOLD
http://nuke.rv9.it
05-01-2011, 12:57 AM
I've had success slipping a crow bar behind places like that. Even bucked one non-structural rivet with a slotted screw driver, pushing on the center portion of it with a bucking bar. Still made a decent shop head.
Next?, TBD
IAR-823, SOLD
RV-8, SOLD
RV-7, SOLD
05-01-2011, 09:02 AM
Canopy frame after deck
I know, the 9 is different than the 7, but, on my 7 I installed the forward canopy frame after riveting the top deck.
Steve Stucky
Topeka, Ks
N282S - VariEze 500+ hrs
N283S - RV-7 1400+ hrs
KC-135 A/D/E Boomer (Ret.)
05-01-2011, 09:31 AM
Oh yeah, forgot about those - they were a bit of a pain. I got the edge of a backrivet plate in there.
