04-27-2011, 12:46 PM
RV-8 Fuselage Fuel Line
Hello All,
This is my first post. I have been building an RV8 QB for the past 10 months. Tail feathers are complete and I am working on the Fus and am up to the fuel system.
I was wondering if anyone has had a hard time forming the 3/8" fuel line that goes between the Airflow fuel pump and the firewall fitting. The drawing shows a simple "S" bend. I have not been able to get the line bent and leave enough room to get the flare tool on the end to form the flare with AN hardware in place???? I was thinking about making the tube straight with flares and hardware and then bending?
Any thoughts or help would be greatly appreciated.
Al
04-27-2011, 01:23 PM
If I remember, that was one of the easier ones. Once you get the 'S' bent so the ends 'mate' with the pump and FW fitting, put fittings one one end and flare it. Then repeat for the other side. I had no problem using the flaring tool on that piece.
That said, I think I am going to get the Bonaco kit for the RV-8. Of all the tubing I have done, the Filter->Pump->Firewall are the only ones I am really happy with. The rest are 'OK' after multiple tries.
Greg Piney
RV-8 2547
Empennage Done!
Beginning Fuselage Final Assembly!
(Tub finished, on to Landing Gear).
04-27-2011, 01:43 PM
fuel lines
I also found this very difficult. Here is a pic. I'm actually not happy with the S tube, as it flattened oh so slightly on one of the bends, so I will probably redo it when I get stuck with other parts of the project.
Click on the image for the full article and another picture.
04-27-2011, 01:55 PM
try a 360 loop
sort of. a descending one.  . made it an easier fit for mine.
Originally Posted by Al RV8
Hello All,
Al
David Edgemon
RV-9A N42DE
RV-8 N48DE
whats next ??
Track me!
04-27-2011, 02:16 PM
...I was wondering if anyone has had a hard time forming the 3/8" fuel line that goes between the Airflow fuel pump and the firewall fitting. ...Any thoughts or help would be greatly appreciated.
Is the firewall drilled yet? If not, you might consider moving the fitting. I moved mine over to the right side of the firewall which made the pump to fitting run much easier, and also shortened the flex line to the fuel pump quite a bit. I considered it a win/win.
Michael Robinson
______________
Harmon Rocket II -SDS EFI
RV-8 - SDS CPI
1940 Taylorcraft BL-65
1984 L39C
04-27-2011, 02:27 PM
Senior Curmudgeon
Welcome to VAF!!!!
Hello All,
Al
Hey Al, welcome to VAF
Good to have you aboard.
RV 8-----I want one.....
Have you considered making use of a hose instead of a hard line???
I know a lot of folks here have taken that approach for some of the fuel system challenges.
I do not know if it would be appropriate for this instance, but thought I would float the idea.
Have fun,
Mike Starkey
VAF 909
Rv-10, N210LM.
Flying as of 12/4/2010
Phase 1 done, 2/4/2011
04-27-2011, 03:19 PM
Thanks All!!
I've got some good ideas from your inputs. I think I need to go with a bigger "S" or loop. I was trying to go almost straight across with two 45 degree bends (what the drawing shows) and was running out of room.
I guess there is no problem with flow through a loop or reversing bend due to trapped air.
Thanks again,
Al Rubin
04-27-2011, 04:31 PM
Hello All,
I was wondering if anyone has had a hard time forming the 3/8" fuel line that goes between the Airflow fuel pump and the firewall fitting. Al
Al,
Short answer yes. I did several of my lines 2 or 3 times to get them right. I think this is one of the those "skill set" issues and that comes with practical experience. Consequently I had to do a lot of repeats before I finally got the knack. Just keep at it.
Don
Don Stiver
RV8 "Little Pill" N6371S, Merritt Island, Fl.
BPE IO-390, Dual P-mag, MT 3-blade, AFP system
Steen Skybolt: Sold
04-27-2011, 05:21 PM
just remember-
To give yourself some flexibility. Mickey's setup looks really good, and allows for some movement. Be careful of your flares, and you'll do great!
Tom
Ridgeland, SC
04-27-2011, 08:18 PM
You could use an AN833 Bulkhead 90 degree fitting at the firewall. Then all you'd need would be to bend the tube 90 degrees.
Dave
