Old 04-23-2011, 02:54 PM
John R. Graham John R. Graham is offline
Default Something Must be Wrong!
On the vertical stabilizer, there nothing that needs to be fabricated, ground down, trimmed, bent, or modified because it's for another airplane. I think I'm going to finish this part in less than a day!
- John
Old 04-23-2011, 03:17 PM
Vlad Vlad is online now
- John
Do not worry John you will get your portion of trimming/bending canopy is coming soon.
Old 04-23-2011, 04:38 PM
AltonD's Avatar
AltonD AltonD is offline
There is a piece of the bracket for the spar that needs to be trimmed. I screwed mine up and it was the first part I had to replace. You don't forget that.
Now that I think about it, that was on the horizontal stabalizer. My bad. The vertical was the easiest, that is why I put it together first.
Alton DeWeese
N526RV RV7A Tip Up, IO360 180 W/Hartzel BA prop.
Flying ~950 hours since Aug 2010
N4IDH
Construction Log
?The secret of getting ahead is getting started. The secret of getting started is breaking your complex overwhelming tasks into small manageable tasks, and then starting on the first one.?
?Mark Twain
Old 04-23-2011, 06:03 PM
That makes more sense. You had me worried.
- John
Old 04-23-2011, 06:49 PM
AltonD's Avatar
When I first started, I would get to the steps the said "fabricate". I would cringe. By the time you are finished, you will read a step to fabricate and not even blink. Of course, when the instructions first start, they give plenty of detail. By the end, the instructions are down to "Fabricate part xxx, see drawing zz for details."
There must be so much fabrication in the kit to meet the FAA rules. There are parts that make no sense to have to fabricate. I guess the biggest fabricate accomplishment for me was the forward tank attach bracket. It was not hard, just an accomplishment to take this big chunk of aluminum angle and make the bracket.
Alton DeWeese
N4IDH
Construction Log
?Mark Twain
Old 04-23-2011, 07:39 PM
BlackRV7's Avatar
BlackRV7 BlackRV7 is offline
- John
John, don't worry....I had three people stop by my shop with their 7 VS's and they walked away with a primed, deburred completed airplane part in a long afternoon. As Vlad said......the canopy awaits you
Dana Overall
Richmond, KY i39
http://www.DanaOverallCPA.com
Repeat offender, RV-10 emp
Builder/former owner, RV-7, "Black Magic" Flying
http://www.youtube.com/watch?v=MMi05-WU2D0#GU5U2spHI_4
VAF #993
Old 04-24-2011, 12:50 PM
JurgenRoeland JurgenRoeland is offline
Soon you will be at the elevators and you will think back how beautifull life was while you were doing the vertical stabilisor
Sorry for the cynism but I just finished bending the trim tab edges. You will understand the remark as you get to it
Jurgen Roeland
RV7 builder Belgium
www.jursairplanefactory.com
