Go Back   VAF Forums > RV Firewall Forward Section > Propellers
  #11
Old 03-30-2011, 12:21 PM
Originally Posted by dealfair View Post
I bought one from Mike Demuth in late 2005 and put close to 200 hours on it before doing a refurbishing job on my -4. I have a 3 blade Catto I'm going to try out.
I hope you will report back on how the switch from the Aymar-Demuth to a 3-blade Catto performs. I personally am very interested as this is exactly the switch I have been contemplating (and mostly for the same reason
Old 04-19-2011, 08:45 PM
petersb petersb is offline
Have flown 1600 hours the last 11 years with a Demuth 68 x 74 prop. Static RPM 2350, climb RPM @ 130 mph 2450. Normally runs 300 RPM above manifold pressure at lower altitudes. Runs 2750 @ 7500 feet TAS 205mph
Tried another prop that ran more square, however, would not produce the same top speed.
Prop is painted wood. Cannot find a better overall match
Peter
Old 04-19-2011, 11:55 PM
gasman gasman is offline
Peter
For this post to be useful, we need to know A/C type and motor...............
I got RV6 from your profile________________
Old 04-20-2011, 09:46 PM
RonRV8 RonRV8 is offline
I purchased a new wood/composite prop from Mike Demuth about a year ago. Beautiful craftsmanship. Runs smooth. I am very satisfied.
Ron
Old 04-21-2011, 08:39 AM
rvator51's Avatar
rvator51 rvator51 is offline
I have been using a Demuth prop since 2002 on my RV-4 after my Props, Inc. propeller failed in flight. Real happy with its performance.
Regards,
Thomas Velvick
Goodyear, AZ (KGYR)
2020 Donation sent.
N53KT RV-6a finished 2018, Flying
N7053L RV-4 Wife's RV
N56KT RV-4 Finishing
Old 04-21-2011, 09:21 PM
Yes , aircraft type is RV6 with a Lycoming O-320-D2J of 160 Hp. The engine by the way has 4000 hours since overhaul, compression 78/80 on all cylinders, normal oil pressure, burns 1 litre per 10 hours and still has the same static rpm as it did when I bought it at 2300 hours.
Old 04-21-2011, 09:46 PM
badmrb badmrb is offline
I had one on my RV6a that performed well ..... Until it failed in flight. Chucked a big wedge piece from one tip. Cant tell ya the reason, but it does wake you up.
Old 04-22-2011, 01:55 AM
ratc's Avatar
ratc ratc is offline
Default Aymar-Demuth propellers!
I may have had some Mis-Information but I was told by a fellow builder here in the UK that Aymar-Demuth had stopped producing propellers at the end of 2010!
Can anyone throw some light on this? If it is wild rumour I'll set the record straight!!
Andy
RV-4
#4411
G-RATC
Old 04-22-2011, 04:53 AM
pierre smith's Avatar
Default Say what???
4000 since overhaul! Incredible! I hope it's not a misprint because that has to be a new record. I've personally seen two go 3,000 hours but 4,000..amazing.
Best,
Pierre Smith
RV-10, 510 TT
Air Tractor 402 PT-6-20 Sold
Louisville, Ga
Patrick Kenny, EAA 275132
Dues gladly paid!
Old 04-22-2011, 07:14 AM
caryr's Avatar
caryr caryr is offline
I put a previously flown AD prop on my O-360 RV7 in 2003.
I just replaced it last year with another one.
Good performance and smooth.
I had refinished the old one several times and it had a small crack in the wood grain.
It is retired and decorating the hanger wall presently.
Cary Rhodes
Taylorsville, Georgia
N203CR
Van's RV-7
First Flight April 2004
