04-06-2011, 12:04 PM
Wing spars
It says to prime the holes after countersinking the spar. What ideas are there out there on doing this with out making a mess.
Mike
Mike Betti
04-06-2011, 12:34 PM
On pretty easy option: I put some primer in a cup, and used a q-tip to touch up each countersunk hole. No mess.
RV7A/TU Finishing Kit
04-06-2011, 06:40 PM
Thanks, that works great.
Mike
Mike Betti
04-06-2011, 10:41 PM
Masking tape
Another idea is to apply a strip of that blue masking tape over the flange before countersinking. Then when you countersink through the tape, you end up with perfectly masked holes ready to be sprayed.
Don't forget to set your microstop cage a couple clicks deeper to compensate for the tape thickness.
Good luck,
Mike Cencula
RV-7A (fuselage)
www.our7a.com
Betcha my pile-o-scrap is bigger than your pile-o-scrap.
04-08-2011, 06:32 PM
We alodined ours. Just take a little acid brush and dip it in Alodine, then put a drop in the countersink. Surface tension will hold the drop there, completely filling the hole/countersink...you can do a couple dozen, let them sit for a bit, then wipe down with a wet paper towel and blow dry. Looks nice, quick and easy, and no need to mess with paint (also avoids the loss of countersink depth due to paint thickness).
Just another option...
Steve
Steve "Flying Scotsman"
Santa Clarita, CA
PP-ASEL, ASES, Instrument Airplane
RV-7A N660WS flying!
#8,000
04-08-2011, 07:46 PM
Alodine stick followed by Q tip with primer.
Walt Aronow, DFW, TX (52F)
EXP Aircraft Services LLC
