Old 04-18-2010, 04:13 PM
breister breister is offline
I'll second the question above and add one:
1. Is the connector plug-and-play with a II VSGV?
2. What is the trade-up policy / cost?
Old 04-19-2010, 07:50 AM
TrutrakTech TrutrakTech is offline
Pierre,
You'll need the 880 with GPSV.
Trade in policies haven't been decided at this time. We'll work hard to make the connector as close to the same as we can. Thanks!
Trutrak Tech Support
trutrakap.com
Old 04-19-2010, 09:50 PM
Captain Avgas Captain Avgas is offline
Default Very very small screen
I notice that no-one has mentioned how small the screen is on this new TruTrak offering. My guess is that it's under 3" diagonal.
That size of screen is way smaller than the smallest Dynon and I'm wondering out loud if it is realistic to have a 6 pack PFD on such a small screen. I'm not certain I'd like to be flying in serious soup with so much info crammed onto such a small screen.
Bob Barrow
RV7A
Old 04-19-2010, 10:10 PM
hughfi hughfi is offline
Default Does it require a seperate AHRS?
Or is in integrated like an AFD1000 or Dynon D10A?
Thx.
Hugh
Old 04-19-2010, 10:28 PM
KRviator's Avatar
KRviator KRviator is offline
For use as your PFD, then yes, it's probably not ideal...
However, for what I believe is their intended purpose - a 3.5" backup with the lot - then they're about as perfect as you're going to get in the one instrument. You only have to look at the old mechanical backups on the airliners of yesteryear, their ASI and ALT tapes were a lot less user-friendly than the Gemini offering...
Once you have tasted flight you will forever walk the earth with your eyes turned skywards, for there you have been and there you will long to return - Leonardo DaVinci
My Flickr gallery: http://www.flickr.com/photos/35521362@N06/
RV-9A - Finished on 10th February 2016 after 4 years, 9 months and 19 days! The 1020th RV-9 flying.
First flight 26th March 2016. Essential specs 145KTAS @ 2400RPM, 8000', 24.2LPH, Initial RoC 1800FPM.
Old 04-20-2010, 08:28 AM
KRviator is correct. They are intended as backup instruments, not as primaries. At this time we haven't decided if we are integrating the AHRS or using a separate module. Most likely we will integrate it like our ADI.
trutrakap.com
Old 04-04-2011, 03:21 PM
flyingbeaver26's Avatar
flyingbeaver26 flyingbeaver26 is offline
Default still under development???
Its been a year since they announced this gemini series of autopilot heads. Floating this thread back to the top. Is this Gemini project under development anymore? Did anyone at Sun n' Fun ask Trutrak about this? I'd like to get one but need to make a purchase pretty soon. I'd like to understand if this project has been cancelled all together.
Brad
RV-8 wiring
Old 04-04-2011, 04:14 PM
rocketbob's Avatar
Yep they're now saying ready by Oshkosh.
Bob Japundza CFI A&PIA
N678X F1 Rocket, under const.
N8155F C150 flying
Not a thing I own is stock.
Old 04-05-2011, 04:58 AM
Yes, I understand. But when the primary fails in soup...the back-up becomes the primary. That's a LOT of information on a VERY small screen for a pilot attempting an IFR approach. Obviously it would be considerably better than nothing at all but I'm just thinking aloud when I wonder it it would be ideal in those circumstances.
Bob Barrow
RV7A
Old 04-05-2011, 05:57 AM
B25Flyer B25Flyer is offline
As previously mentioned, you have obviously never seen the standby peanut gyro in a business jet... It is fits in a 2 1/4" hole and it tiny by comparison to the Gemeni. I can't wait for the autopilot version. The 880 will have altitude preselect!!! Yippeee!!!!!
Even with my altitude alterter I have busted altitude on long climbs a couple times... One time I got the dreaded call from the feds. They did an investigation and all I got was a letter in my file that falls out in another year.
I can't wait for Altitude preselect.....
