Old 06-03-2006, 02:17 PM
tx_jayhawk tx_jayhawk is offline
Default Stick Grip Questions
All,
Trying to decide on a stick grip, and I had a couple of questions I was hoping others would know.
1) Are the Ray Allens the only ones that don't require the use of a relay for the trim motor (for a single switch)? The new G307 advertises 15 amp Honeywell switches, and that seems to be an attractive selling feature.
2) What type/quality of switches comes with the Teak wood units that Spruce sells? Calling them is no help...they never seem to have any answers.
3) What type/quality of switches comes with the CH stick? Given that is basically an arcade joystick that they renamed "aircraft", I might be worried about the quality/longevity of those switches.
4) I know the Infinity switches come pre-wired, but do any others? Specifically I am wondering about the CH, Ray Allens, and Teak wood. Given the CH seems to be a one piece unit, I assume it does. I guess you can't replace switches on it.
5) Can you replace switches on the Teak wood or new Ray Allens?
Sorry for all the questions...I guess it was more than two. I am leaning towars the Teak wood for beauty, and the Ray Allens for function.
Scott
7A Finishing
Old 06-03-2006, 03:11 PM
L.Adamson's Avatar
L.Adamson L.Adamson is offline
The new Ray Allens with the four way hat switch still use individual micro switches like the old ones did. Would be easy to replace.
I had the old stick before, and replaced with the new style. I've angled the new style to the left, for a comfortable hand fit, since it's more of a formed grip.
Old 06-03-2006, 03:55 PM
rv8ch's Avatar
rv8ch rv8ch is offline
Default Grips
I've heard from other builders that the CH grip is nice. I have the Ray Allen 307, and it does not come wired. I've got info here about my wiring experience:
http://www.rv8.ch/article.php?story=20041120212301548
I didn't enjoy wiring it, but it turned out ok. If I were to do it again, I'd probably go with the CH, just to avoid the wiring.
Mickey Coggins
http://rv8.ch
"Hello, world!"
Old 06-03-2006, 04:28 PM
kevinh's Avatar
kevinh kevinh is offline
The teak sticks are really nice - except that the rubber boots are easy to break off of the switches. The guy that makes the teak sticks is great to talk with, if you call AS&S they can get his phone # off of the bags they are packaged in. He is happy to answer questions and even making custom changes to the sticks for no fee (i.e. if you want an extra switch or one less). He can also make lefty versions.
He sent me mine with a note to just send it back if I didn't like it or send a check if I did.
Don't worry about wiring up the relays, they are easy to work with. Just mount em on the belly near the stick.
-kevinh, Track my RV-7A, flying, alas, sold in 2013 after 450ish hours. (I'm now building something different)
Old 06-03-2006, 04:42 PM
jedimike007 jedimike007 is offline
The CH sticks are really nice. It appears they can come apart for replacement of the switches, however I havent tried to. Very comfortable for hand placement , and they come prewired. Pm me for pics, I think I have a set if your looking.
Mike
Old 06-05-2006, 08:31 PM
N969LS N969LS is offline
I purchased the ch grips. I have flown with the ray allens grips and did not like them. Call Kevin at CH, he has a RV6, he'll take care of you. http://www.chproducts.com/retail/aircraft.html price wise, they are the best and they are pre-wire. kinda hard to beat. I would not worry about the switch on the grip, have you ever seen a kid play a video game? if they hold up to that, i think ill be considered a light user.
Just my thoughts.
Lamar Lawson
N217NL Reserved
Old 06-05-2006, 09:27 PM
L.Adamson's Avatar
I suppose I need to ask why, you didn't like the Ray Allens? I've had both types and like them. The new ones have the triangular top piece with a hat switch and two buttons in addition to the PTT switch. They are very well built with quality switches, along with a very good setup for bolting to the joystick.
They are molded to fit your hand grip, and "should" be angled to the natural angle of your fist to be comfortable. I have seen some mounted straight, and I don't think I'd like them either..........in that case.
Old 06-06-2006, 05:37 AM
RV_7A RV_7A is offline
CH man, they now have relays built into the grip which makes wiring quite simple.
-Jeff
www.JeffsRV-7A.com
N808TX
Old 06-06-2006, 08:00 AM
rv72004 rv72004 is offline
Dont fret over relays, the wiring is quite simple.Pick the grips you like.
I opted for the infinity grips and am very happy with my choice.
Old 06-06-2006, 08:34 AM
I have the older CF grips w/o the relays built in and I agree the wiring is pretty straight forward but why bother?
www.JeffsRV-7A.com
N808TX
