I would not buy any commercial fasteners that have a critical purposes from these type of business's.
A) Big box stores that do not do their purchasing at their local facility, as it seems that most of them have no idea what country they are made in, and I would not trust the sticker on the little plastic bin box that have been co-mingled.
B) Bolts 1/4" dia that have Head Markings that are not recognizable or absent.
C) Things that look questionable, its not worth the risk.
There are hundred of good distributors of commercial fasteners in every state. They should have traceability and certs on file.
The Manufacturers are required to meet the applicable parts of the fastener quality act. The link has the word metrics but it also applies to US fractional fasteners, Grade 5 and above.
http://www.nist.gov/pml/wmd/metric/upload/fqaregs2.pdf
You should be able to get the Lot# on a certificate of conformance from the legitimate distributor.
Caveat.... When they ask you what it's going on and you tell them its for a plane, they may be hesitant to deal with you.
Tell them that it is not a critical part,( it should not be ) you just need to ascertain it is made to the standard to which it is head marked.
On a steel Fastener no marks= Grade II (soft junk, stay away)
This should help.
As a comparison, regular AN bolts have a tensile strength of 125 ksi.
NAS series bolts
http://www.gen-aircraft-hardware.com...pdf/nashhb.pdf NAS bolt have a tensile strength of 160 to180 ksi.
http://www.tessco.com/yts/customerse...bolt_grade.pdf
Remember YOU are the manufacturer of the Aircraft and responsible for its airworthiness.
I hope this clears a few things up, sorry it may still take time for you to procure for your individual requirements.
