Go Back   VAF Forums > Model Specific > RV-9/9A
  #31
Old 03-21-2011, 10:52 AM
ALMARTON ALMARTON is offline
Hi folks,
As promissed finally let me update this post with my results/tests after this first sunny weekend here...
I tried WOP (wide open throtle - full throtle) , full rich, 2650rpm (Hartzell) in my RV9A with Lyc 160hp and the max I got was 159mph IAS (that gave me 186mph TAS). EFIS was reading 91% power (think it would never got to 100% though cause I was already full throtle...)
That was maximum speed I got level flight (8000ft DA).
Thanks all for the comments and tips, regards;
Alexandre "neck" Marton
Brazil
RV7A (8/2015 built by FLYER)
Lycoming 180 HP - YIO-360-M1B, Hartzell C2YR-1BFP/F7497? 72??, Garmin panel - G3X Touch, GTN650, GTS800, WX-500, BATT CONCORDE RG-25XC AEROBATIC SEALED.
Others: RV9A
Lycoming XIO320-D1A, Hartzell HC-C2YL-1BF/F7663-4 , CS GOVERNOR MTV-12-B, DYNON D180
AND GARMIN AVIONICS
(Sold with aprox 300hrs flown from Dec/2010 -- JUN/2014)
Old 03-21-2011, 11:17 AM
Default That is going to be very tough I suspect
There are a lot of things you can do to reduce drag beyond the stock completed airplane with all of its fairings. In my RV-6A the initial tested three direction maximum baseline speed at 6000 ft density altitude was 170.67 kts. I have tried a lot of things and reported them in this forum. Many did no good or even reduced the speed. The top speed I have been able to achieve is now 184.4 kts.
Bob Axsom
Old 03-21-2011, 12:52 PM
kentb's Avatar
kentb kentb is offline
Default Neck, you plane is looking good.
Originally Posted by ALMARTON View Post
Hi folks,
The EFIS power table should be adjusted. With those setting the power indictation is to high. I don't know the correct formula, but I would think something around 75 - 80 percent power.
Kent
Kent Byerley
RV9A N94KJ - IO320, CS, tipup
AFS 3500, TT AP, FLYING....
Canby, Or
Old 03-21-2011, 02:02 PM
videobobk's Avatar
videobobk videobobk is offline
On my 9A, I went from 188 to 192 WOT when I put on the second P-Mag. The first one cut my fuel burn, but didn't increase the performance noticeably. When I added the second one, it didn't cut the fuel burn much , but added about 4 mph top. This was with a waxed plane, and I can see a difference, although I haven't done any serious measurement.
Bob Kelly
Bob Kelly, Scipio, Indiana
Tech Counselor
Founder, Eagle's Nest Projects
President, AviationNation, Inc
RV-9A N908BL, Flying
Old 03-21-2011, 04:49 PM
ChiefPilot's Avatar
ChiefPilot ChiefPilot is offline
Hi folks,
Full rich @ 8000ft DA will cost you some power; leaning for "best power"/slightly rich-of-peak will get it back for you if your engine is broken in and otherwise able to run there.
Brad Benson, Maplewood MN.
RV-6A N164BL, Flying since Nov 2012!
If you're not making mistakes, you're probably not making anything
Old 03-22-2011, 01:53 AM
bignose bignose is offline
Default Wasting Fuel
Plus = Full Rich - WOT at 8000 feet will certainly waste a lot of unburned fuel and leave you a black smoked belly and maybe some fouled plugs
