Old 03-08-2011, 06:53 PM
RV8R999 RV8R999 is offline
Why is Deakin more an authority than Lycoming? I'm very interested in hearing this rationalization...
Old 03-08-2011, 07:52 PM
John Clark's Avatar
John Clark John Clark is offline
Default Good science
See Hans' post #109. A lot of research and genuine science went into Deakin's writings. The test cell work done by "GAMI" (short for "General Aviation Modifications, Inc.," of Ada, Oklahoma,) was the basis for Deakin's writing on engine management. I suggest reading the whole series and compare it to Lycoming's probably-written-by-an-attorney advice. Rationalization? not really, just good science.
John Clark ATP, CFI
FAA FAAST Team Member
EAA Flight Advisor
RV8 N18U "Sunshine"
KSBA
Old 03-08-2011, 08:46 PM
Ironflight's Avatar
VAF Moderator / Line Boy
I agree completely with John - Deakin is quoting some very good research done by the guys at GAMI, and I subscribe to a lot of what he says about running Lycs LOP. That said, it should be noted (and Deakin notes this himself somewhere), that most of their work applies DIRECTLY to the larger Lycs and Continentals, many of which are turbocharged, and are known to be easily toasted and otherwise damaged by improper operating technique. It has been my anecdotal experience that the four-bangers are pretty rugged and forgiving of abuse, so long as that abuse isn't dished out at close to 100% Power. Lycoming themselves say that at 65% or below, you can't damage the engine no matter where you run the mixture. of course, I have not seen the science that came up with that number....
Paul
Paul F. Dye
RV-8 - N188PD - "Valkyrie"
RV-3B - N13PL - "Tsamsiyu"
Dayton Valley Airpark (A34)
http://Ironflight.com
Old 03-09-2011, 01:57 AM
bignose bignose is offline
Default Ultratraditional
Originally Posted by nucleus View Post
Deakin backs his recommendations with science, Lycoming doesn't. That is why Deakin's recommendations are not dogma and Lycoming's are.
Hans
Lycoming is building bullet proof aircraft engines for more than 100 years now.
Certainly they have their own scientific department employing the best engineers you can get...
It's like willing to teach Victorinox how to build military knifes ... or Peterbilt how to make truks and Caterpillar their Bulldozers.
Old 03-09-2011, 10:28 AM
RVbySDI's Avatar
RVbySDI RVbySDI is offline
Comparisons of "Building" to "Operating" a product are comparing apples and oranges. Telling "Peterbilt how to make truks and Caterpillar their Bulldozers" is not the issue here. No one is discussing the issue of telling Lycoming how to build aircraft engines. This discussion is about how to operate those engines.
RVBYSDI
Steve
RV9A
https://rvwings.com
Live Long And Prosper! 🖖🏻
Old 03-09-2011, 12:09 PM
David Z David Z is offline
Lycoming's reputation is dependant on how the engines are operated.
Lycoming is going to tell us to operate them the best way possible to ensure long engine life and maintain their reputation.
Not everybody has CHT and EGT gauges, yet alone one on every cylinder. That increases the risk of LOP so Lycoming doesn't recommend it.
RV-8
Empennage Passed Pre-close Inspection
Wings mostly done
Fuselage is "in the mail"
83126
Dash 8 day job is financing the RV-8
Donation till September 2021
Old 03-09-2011, 12:42 PM
RVbySDI's Avatar
I agree with your statement. Lycoming is going to give out directions with the motivation in mind to protect their reputation as you say. True, true.
However, as more substantiated evidence reveals details that show the effectiveness and viability of running engines LOP it is only going to become clearer that the decision by Lycoming to come out against running their engine LOP is being driven by business motivations and not operational limitations of the engines to be able to successfully run LOP without adverse effects.
RVBYSDI
Steve
RV9A
https://rvwings.com
