Old 03-05-2011, 07:25 AM
novipilot novipilot is offline
Default Heated Pitot
Is there a heated pitot tube available for the 9A?
Old 03-05-2011, 07:49 AM
B Cunningham's Avatar
B Cunningham B Cunningham is offline
Google or search here: "Gretz pitot"
Ben Cunningham
RV7 N701VF
Bowman Field, Louisville, KY
Old 03-05-2011, 08:06 AM
Greg Arehart's Avatar
Most any heated pitot can be made to work, although you may have to modify the mount to fit the RV.
greg
Greg Arehart
N 7965A
Old 03-05-2011, 08:08 AM
mgomez's Avatar
mgomez mgomez is offline
Default Spelling
Originally Posted by B Cunningham View Post
Google or search here: "Getz pitot"
Gretz pitot tube
Martin Gomez
Redwood City, CA
"My RV-7 is a composite airplane: it's made of aluminum, blood, sweat, and money"
RV-7 Slider QB
Old 03-05-2011, 12:24 PM
terrye terrye is offline
Default RV-9A Heated Pitot
Used Cessna 150/152/172 heated pitot with Safeair mast.
Old 03-05-2011, 03:47 PM
Buggsy2's Avatar
Buggsy2 Buggsy2 is offline
Dynon Avionics.
Ralph Finch
RV-9A QB-SA
Davis, CA
Old 03-07-2011, 07:17 AM
krw5927 krw5927 is offline
How's the fit of the Cessna pitot on the Safeair mast, terrye?
Old 03-07-2011, 06:29 PM
Default Cessna Heated Pitot
krw5927
The fit is excellent, the Cessna conforms to the AN spec for pitot tubes. I have an older Safeair mast made of steel tubing, so I can't speak for the newer one. The only issue was trying to match the layout of the Cessna mounting holes and countersink the holes in the Safeair mast. After some messing around it worked OK.
Terry
Old 03-16-2011, 08:05 AM
jimbo jimbo is offline
Also, Used Cessna 150/152/172 heated pitot bought thru Ebay with Safeair mast.
I cut 1" off the length of the Safeair mast. Takes a little time to get the hole in the wing bottom skin to fit the pitot tube shape.
I found that the Cessna pitot tubes take the #6 screw with 40 thread. Screws thru the mast into the pitot tube. Very hard to find in case you want to buy in bulk and have gazillions left over. Still looking for 4 of them.
Jim
Old 03-16-2011, 08:16 AM
LifeofReiley's Avatar
LifeofReiley LifeofReiley is offline
The Piper Blade really looks good on these RV's...
Reiley
Retired N622DR - Serial #V7A1467
VAF# 671
Repeat Offender / Race 007
Friend of the RV-1
