Go Back   VAF Forums > The Never Ending Debate Section > Nosewheel vs. Tailwheel
View Poll Results: Have you ever ground looped or bent a nose gear in a RV
Yes, I have ground looped my RV 4 2.17%
I fly a tail dragger RV 99 53.80%
Yes, I have bent my nose gear on my RV 6 3.26%
I fly an A model RV 85 46.20%
Multiple Choice Poll. Voters: 184. You may not vote on this poll
  #31
Old 02-24-2011, 10:49 AM
1:1 Scale 1:1 Scale is offline
Originally Posted by John Clark View Post
The methodology is seriously flawed. First, there is no mention of hours flown. The statistic should be expressed in events per XX hours.
As someone mentioned earlier, what does hours flown have to do with the occurance of ground handling incidents? Are we talking about PIC hours, or hours on the aircraft? If you want to make the data more "accurate", it should be based on the number take offs and landings, not hours flown.
I find the poll interesting, but take it with a grain of salt. It's surely not a master's thesis
Kelly
RV-7 empennage done, wings done, fuselage to QB stage.
1973 Maule M4-220C flying
Old 02-24-2011, 11:05 AM
John Clark's Avatar
John Clark John Clark is offline
Default Time
You are right, comparing the incidents to the number of take off/landings would be good. Also, a breakdown of pilot time, total and in type, would be interesting.
John Clark ATP, CFI
FAA FAAST Team Member
EAA Flight Advisor
RV8 N18U "Sunshine"
KSBA
