Go Back   VAF Forums > The Never Ending Debate Section > Nosewheel vs. Tailwheel
Old 02-17-2011, 08:02 PM
randyintejas's Avatar
randyintejas randyintejas is offline
Default Help Convince Me
I am ordering my wings and fuse kits next week. I have 720 hours in nose wheel aircraft but, after reading all the post on VAF about Tail Draggers I?m now on the fence. I have my Emp for my 7 done and ready to move forward so, the facts seem to be..
1. Faster. No nose gear to drag around
2. More interior space. No weld mounts in the way
3. More capable of landing on grass strips
4. Lower to the ground so, easier to load and enter.
5. Easier to install and remove cowl
I have also just discovered that Alex at Eagles Nest is just hour and a half from my house for training.
What else am I missing?
I do enjoy a good can of worms.
RV 7
391RK Reserved
IO360 9:5:1 AFP
Slow Build
Last 90%
Tyler, Texas
Old 02-17-2011, 08:11 PM
rocketbob's Avatar
Think of all the neat airplanes you are denying yourself the ability to fly by not building an airplane you can gain this valuable experience with.
Bob Japundza CFI A&PIA
N678X F1 Rocket, under const.
N8155F C150 flying
Not a thing I own is stock.
Old 02-17-2011, 08:15 PM
John R. Graham John R. Graham is offline
Order your wings and stew about it some more while you work on 'em.
- John
Old 02-17-2011, 09:06 PM
L.Adamson's Avatar
L.Adamson L.Adamson is offline
Tougher to see objects on the taxiway...........that shouldn't be there..
Seems that a Pitts that I use to fly, and an RV9 had a common problem with tractors that pull airplanes around. The Pitts was returned to the factory for repairs, and the 9 went back to it's factory........also.
L.Adamson --- RV6A
Old 02-17-2011, 09:07 PM
DanWright DanWright is offline
Insurance rate differential. Conventional wisdom is that there are two kinds of tail dragger pilots, those who have ground looped and those who are going to. While I know us RV types are special, the conventional wisdom is not without some basis.
Old 02-17-2011, 09:12 PM
pjaffray pjaffray is offline
Tail draggers look cool.
I am building an 8 and recently got my tail wheel endorsement in a Pietenpol. I also learned how to repair a wood and fabric airplane thanks to a not so great landing. But I am having a blast flying the Piet.
pdj
RV-8 Finish kit stage.
Old 02-17-2011, 09:20 PM
L.Adamson's Avatar
All depends. I like WWII military paint schemes. So yes, the 8 looks cool as a tail dragger. But when I compare a nose wheel retractable Glasair to the tail dragger version, the retract wins by a mile. Both in the air, and on the ground. A 7 can be either...........since it's wings are a bit longer than a squatting dog 6...
And yes, I know a tail dragger pilot who has damaged two...as of now.
L.Adamson --- RV6A, would like an Aviat Husky & Cessna Citation 10
Old 02-17-2011, 09:23 PM
pazmanyflyer's Avatar
pazmanyflyer pazmanyflyer is online now
Don't forget the sexy factor! The 7's stance is sexier than the -A IMHO anyways. Chicks dig sexy!
Carlos in Arizona
EAA Chapter 538 www.chapters.eaa.org/eaa538
Wittman Tailwind W8 N53CH (built & sold)
Pazmany PL-1 N2029 (bought & sold)
RV7 - N537TC (reserved & building)
Emp, Wings & Fuse done - working on FWF
"The air is an extremely dangerous, jealous and exacting mistress. Once under the spell most lovers are faithful to the end, which is not always old age." - Winston Churchill
Old 02-17-2011, 09:26 PM
Default Insurance rate differential
good point. what is the insurance rate difference?
RV 7
391RK Reserved
IO360 9:5:1 AFP
Slow Build
Last 90%
Tyler, Texas
Old 02-17-2011, 09:32 PM
N941WR's Avatar
N941WR N941WR is offline
Zero, zilch, nadda.
Radomir and I started flying our planes at the same time and had the same TT, but I had a little over 100 hours TW.
He had a -7A, I had my -9, and our insurance rates were the same (when the different insured hull values were taken into account).
It wouldn't surprise me if the rate of "A" tip-overs and non-A ground loops are the same. Meaning, very few for both models and thus the insurance differential is not there.
With either model, you will pay more the first year and then expect your rate to drop once you get 100 hours in type.
Hopefully one of the insurance guys who frequent this board will speak up on the subject.
Bill R.
O-360 w/ dual P-mags
SC86 - Easley, SC
www.repucci.com/bill/baf.html
