Old 02-16-2011, 07:21 PM
Spindrift Spindrift is offline
Default Dynafocal mount orientation -- urgent question
Hi all,
My a&p is working on hanging my new IO-360 and is not 100% sure the orientation of the dynafocal mounts. Unfortunately, he doesn't have the right plans to refer to because mine are at my house vs at the airport 1.5 hour drive away where my airplane is stranded, and I'm stuck at work. Can someone take a picture either of their plans or their mounted engine and send me the photos to forward on? A quick forum search didn't turn up an answer.
bill.inman at wwwinc dot com
Thanks in advance!
bill
RV7A QB kit -- sold and now flying in S. Africa
RV7 purchased flying
"A pilot just bides his time until his plane can take him away again, into the air"
-- Jake Grafton (Stephen Coonts, Flight of the Intruder)
Old 02-16-2011, 07:33 PM
hydroguy2's Avatar
got 'em I'll send them in a minute
Default Excellent
Thanks a ton!
bill
Old 02-16-2011, 07:35 PM
LifeofReiley's Avatar
LifeofReiley LifeofReiley is offline
Default Hmm...
The Lord Mounts install just like any other Lycoming Engine...??
Is this what you're asking?
Reiley
Retired N622DR - Serial #V7A1467
VAF# 671
Repeat Offender / Race 007
Friend of the RV-1
Old 02-16-2011, 07:41 PM
http://www.vansairforce.com/communit...ht=engine+hung
Reiley
VAF# 671
Friend of the RV-1
Old 02-16-2011, 07:43 PM
hydroguy2's Avatar
Email sent, but in case anyone else needs to see them.
Lower mounts
Upper mounts
Upper mounts installed
Looks like Reilly out computered me.
Mel's Avatar
Mel Mel is offline
If you are talking about the orientation of the "Lord" mounts; the "hard" mount (the one with the "ring") goes behind the mount on top and between the engine and the mount on the bottom. That puts all the "hard" mounts in compression with the aircraft sitting with one positive G.
RV-6 Flying since 1993 (sold)
<rvmel(at)icloud.com>
Old 02-16-2011, 10:09 PM
Default Thanks all
Mel, I think that is what he was asking me about, but it seems he figured it out because not long after I posted this question, I got a text message with a picture of the engine already hung.
Thanks to everyone for the quick responses.
bill
Old 02-16-2011, 10:59 PM
Jekyll Jekyll is offline
You're in luck, Van's has the Dynafocal I drawings on their web site:
http://www.vansaircraft.com/pdf/revi..._7A_9A_46A.pdf
http://www.vansaircraft.com/pdf/revi.../RV_7_9_46.pdf
Jekyll
7A slider
