Go Back   VAF Forums > Model Specific > RV-9/9A
  #121
Old 01-01-2011, 08:24 PM
Ron Lee's Avatar
Ron Lee Ron Lee is offline
Originally Posted by N941WR View Post
LA, I was watching the fuel flow's at the low power settings I was using and thinking, "Darn, those are higher than the cruise settings I had with the little engine." This bigger engine is going to hurt my wallet!
Just throttle back a bit. You should see similar fuel flow at the same airspeed.
Old 01-01-2011, 09:16 PM
N941WR's Avatar
N941WR N941WR is offline
I'm curious about this. The old prop was a climb prop and this new one should be an uber cruiser. Thus, will I actually see higher airspeeds at the same fuel flows?
Bill R.
O-360 w/ dual P-mags
SC86 - Easley, SC
www.repucci.com/bill/baf.html
Old 01-14-2011, 02:15 PM
N941WR's Avatar
Tomorrow we will roll the -9 across the scales (Same ones we used to do the original W&B), back in 2007 the -9 came in at 990 lbs empty.
Here are the major changes that I have made, which might impact the W&B:
Added Dynon auto pilot (5 lbs)
EICommander (5 oz, call it half a pound with the wiring.)
Replaced the O-290-D2 with an ECi O-360 (21 lbs heavier)
Leather interior (8 lbs)
James holey cowl and cooling plenum (Weight unknown)
Some tie down rings in the baggage compartment
Some dirt
And who knows what else that I have forgotten about.
I?m guessing my new empty weight will be around 1025 to 1030 lbs.
What say ye, what do you think my new empty weight will be?
Bill R.
SC86 - Easley, SC
Old 01-14-2011, 02:36 PM
Bullseye's Avatar
Bullseye Bullseye is offline
Some dirt
Funny, but also sad...
Andrew Z.
Engineering Flight Test Pilot/Engineer, CFI-A, CFII, ATP
RV-7 in work (See my build log.)
Empennage...Done (except rebuilding the rudder.)
Wings...Halfway complete.
2018 Dues Paid
Old 01-14-2011, 03:51 PM
L.Adamson's Avatar
L.Adamson L.Adamson is offline
No paint?
L.Adamson --- RV6A
Old 01-14-2011, 03:56 PM
hydroguy2's Avatar
I'll bite: 1042#
Old 01-14-2011, 04:24 PM
tsneidin tsneidin is offline
My io-360 3 blade catto, leather etc weighed in at 1088, so I'm going with 1079.
Todd Neidinger
RV-9 Flying
Old 01-14-2011, 04:27 PM
scsmith scsmith is offline
Default weight gain with age
I have added various components over the past 6 months, and kept pretty good track of them. I figured I added 12 lb of components. I just reweighed the plane, and it gained 20 lb. How does that happen?
Steve.
Some dirt
Steve Smith
Aeronautical Engineer
RV-8 N825RV
IO-360 A1A
WW 200RV
"The Magic Carpet"
Hobbs 625
LS6-15/18W sailplane SOLD
bought my old LS6-A back!!
VAF donation Jan 2020
Old 01-14-2011, 05:05 PM
Michael White's Avatar
Bill,
We'll keep it to nice round numbers...I'm guessing 1047.5
Moose
VAF #136
Old 01-15-2011, 02:26 PM
Radomir's Avatar
Radomir Radomir is offline
If you said 1,068 you would have been right It flew today and everything looked good...
Radomir
RV-7A sold
