Old 01-13-2011, 04:42 PM
DJR DJR is offline
Default Infinity Stick install/ordering
I'm trying to put together an order for the Infinity stick grip and am having a bit of trouble understanding the order form.
The order form has boxes to check regarding Inside Diameter spacer sizes for either 3/4" or 7/8" and a box for either Long or Short.
For those who have installed the stick in an RV8 (front stick) any advice for a std. install on an 8 is much appreciated. It also asks about extra wire length.
Dana
http://www.infinityaerospace.com/gripwire.pdf
Old 01-13-2011, 05:06 PM
Transporter Transporter is offline
The Infinity stick grip fits the RV8 front stick without any spacers.
I'd recommend getting some extra wire length (total of 6 ft worked for me).
If you call, they'll be happy to discuss any switch options you may be considering.
Good luck,
Mike
Mike Dooley
RV hitchhiker
RV8 SB
VAF#1067, EAA Chapter 91
Old 01-13-2011, 08:04 PM
Jekyll Jekyll is offline
Just call Infinity. The owner loves to talk with builders; he will get you set up just the way you want.
Old 01-13-2011, 08:17 PM
RogerM RogerM is offline
Be sure to remove the paint/powder coat from the area beneath the infinity grip. I didn't and got to do the assembly twice.
Old 01-14-2011, 12:18 AM
Snowflake's Avatar
Really? Why? I'm not so keen on leaving that metal bare... It is just steel, after all. It will rust in time if it's left exposed. Is it just a clearance issue? Maybe just a thin primer coat would be adequate instead?
Rob Prior
Old 01-14-2011, 07:31 AM
Ironflight's Avatar
VAF Moderator / Line Boy
My experience is that he loves to talk TO builders - after he finishes telling YOU what YOU want, then he'll launch off on a political diatribe and tell you all about the secret projects that he's been involved with....
But to the OP, I put a stock (ordered from ACS) Infinity grip on my -8 six or seven years ago with no modifications to stick or grip. Installed a similar stock Infinity on the -3 project a couple of months ago - again, no mods - no problem.
Paul
Paul F. Dye
RV-8 - N188PD - "Valkyrie"
RV-3B - N13PL - "Tsamsiyu"
Dayton Valley Airpark (A34)
http://Ironflight.com
Old 01-14-2011, 08:30 AM
Noel Simmons's Avatar
Noel Simmons Noel Simmons is offline
Default get extra wire
get the extra 6' of wire you will not regret it.
Noel Simmons (repeat builder) just ordered my 40th it's an 8!
406-538-6574
A&P CFI EAA Tech/EAA flight adviser
Old 01-14-2011, 09:18 AM
Veetail88's Avatar
Veetail88 Veetail88 is offline
Default Yeah,
I spent an hour and a half on the phone ordering mine!
Nice enbough guy, I didn't have the heart to cut him off!
Jesse Bentley
N229Z - RV-8 - Flying - Livin' the dream!
Old 01-14-2011, 12:48 PM
bkthomps bkthomps is offline
his site is super confusing, it feels like watching a billy mays commercial when I read it
Old 01-14-2011, 01:01 PM
DJR DJR is offline
Default LOL
Now that is funny. And it's nice to know that I'm not the only one feeling like it's a Billy maze commercial.
Thanks to all who've replied with info. I'll take your advice and just give him a call.
Dana
