Old 01-08-2011, 12:29 PM
MSFT-1's Avatar
MSFT-1 MSFT-1 is offline
Default circuit breaker question for the electrical gurus
I have the Van's HID landing lights on my RV-10 (one on the leading edge of each wing). They are wired to a single 10amp circuit breaker. Occasionally, when they have been on for several minutes (for a long taxi), the breaker will trip. After a couple minutes it will reset without issue. Most of the time this doesn't happen at all (I can leave the lights on for an hour with out a problem).
I am assuming that the lights are drawing enough current to cause that breaker to heat up and trip.
I asked an experienced builder if it made sense to up the breaker to 15amps. He said that might help but I needed to know the wire guage and length to properly determine the safe breaker size.
Can someone help me with this? What size wire should these lights use? How do I do the calculation?
thanks.
Bruce
Richmond, VA (KFCI)
RV-10 (520+ hours since first flight in Nov 07)
RV-8 (500 hours, sold Sept 07)
Old 01-08-2011, 12:33 PM
lucky lucky is offline
Default I've got no idea but
I got all excited because I wasn't wearing my glasses and I thought you were asking about electrifying your RV's GUNS and I was thinking **** Yeah, Let's see this! Man, I'm disappointed....
Lucky Macy
EAA Tech Counselor/Flight Advisor
Old 01-08-2011, 12:53 PM
az_gila's Avatar
az_gila az_gila is offline
Smile
The better idea might be to power them from two breakers not one for a slightly more redundant system.
Is each light switched separately?
Gil Alexander
RV-6A N61GX - finally flying
Grumman Tiger N12GA - flying
Old 01-08-2011, 12:57 PM
Mike S's Avatar
Mike S Mike S is offline
Senior Curmudgeon
Absolutely correct.
The breaker is there to protect the wiring.
I suggest going to individual breakers for each light.
You will then need to re-work the switching, a DPST switch will work, or add a second switch.
Mike Starkey
VAF 909
Rv-10, N210LM.
Flying as of 12/4/2010
Phase 1 done, 2/4/2011
Old 01-08-2011, 01:36 PM
Lux Wrangler Lux Wrangler is offline
Default real men don't
If all else fails, try reading the instructions, under "fuses and breakers":
"For each HID use a 10A" - Duckworks
Jim Peck
San Francisco Bay Area
RV-7
Old 01-08-2011, 02:19 PM
cfiidon's Avatar
cfiidon cfiidon is offline
Default Breaker versus wire size
thanks.
According to my trusty reference, protect 18 gauge wire with a 10 amp breaker, and 16 gauge wire with a 15 amp breaker.
So if you are wired with 16 gauge, feel free to just up the breaker size. You also might consider swapping out the breaker in case it's a "weak" one.
Don
RV-8 QB Titan ECi 191HP XIO-360
WW200RV Dynon D180 HS34 AP74
GNS430 SL30 GTX327 PS8000B Uavionix Echouat
"Pilots are alchemists... we turn gold into lead."
Old 01-08-2011, 09:06 PM
SteinAir SteinAir is offline
As others have pointed out, your choices are kind of limited by your wire size....if you have beefy enough wire then just put in a bigger breaker, if not then add a 2nd breaker or fuse. You're probably in the gray area of current draw being right on the edge of your breaker and environment (how hot things get under the panel, etc..).
My 2 cents as usual!
Stein
Old 01-08-2011, 09:12 PM
Ron Lee's Avatar
Ron Lee Ron Lee is offline
Originally Posted by Lux Wrangler View Post
If all else fails, try reading the instructions....
Cruel. That is against one of the Guy Code rules.
Old 01-09-2011, 07:54 AM
Default I'm a man and I can change, if...
Cruel. - Ron Lee
Well, I wasn't trying to be cruel. I have spent a many day-job-hours writting technical instructions that too few read. On the other hand; I think if I had been following the Red Green example, instead of spending so much time reading the instructions, I would be finished with my 7.
Jim Peck
RV-7
Old 01-09-2011, 08:08 AM
Daver Daver is offline
Default circuit length
circuit length has nothing to do with the circuit breaker.
The wire is sized to the load (upsized for voltage drop if necessary) and the circuit breaker sized to the wire.
Typically circuit breakers should not be loaded past 80% of the continuous load.
Dave
-9A flying
