  #41
Old 01-07-2011, 10:00 AM
Ron Lee's Avatar
Ron Lee Ron Lee is offline
Allan, have you tried Conosol 260 for smoke oil. It is the only thing I have been able to find so far.
Old 01-07-2011, 11:45 AM
PerfTech's Avatar
PerfTech PerfTech is offline
Yes I have used it and had good success. Keep in mind most any type of oil will work so don't be afraid to experiment. Allan
Old 01-07-2011, 09:02 PM
PerfTech's Avatar
Default Now I feel Bad!
Now I feel Bad!
Hi Scott No need for any of that, You were just stating the way you felt at the time and nobody does that more often or with less grace than myself. This is all in fun and for the sake of it, nothing more. I will be coming up your way in a month or so and perhaps we can get together for lunch or to compare notes. Regards, Allan
Old 01-08-2011, 12:20 AM
rvmills's Avatar
rvmills rvmills is offline
Geez Scooter,
You use more 5 syllable words than anyone I know. Pretty soon we'll be calling it a Condensation Nuclei Distribution System! You should teach Englsh or something!
Bob
Bob Mills
RV-6 "Rocket Six" N49VM
Reno-Stead, NV (KRTS)
Old 01-09-2011, 11:02 AM
Jim Wright Jim Wright is offline
Count me in.....a few of us are interested in formation cross countries and it is easy to loose sight of each other.
akflyer@cableone.net
Old 01-11-2011, 09:39 AM
RV7Guy's Avatar
RV7Guy RV7Guy is offline
Default Contact me
Hi Allan,
Please contact me backline (ktlkrn@cox.net) or call me, 480-204-0662.
Darwin N. Barrie
Chandler AZ
www.JDair.com
RV-7 N717EE-Flying (Sold)
RV-7 N717AZ Flying, in paint
EMS Bell 407,
Eurocopter 350 A-Star Driver
Old 01-16-2011, 08:32 AM
DENMACRES DENMACRES is offline
Originally Posted by PerfTech View Post
OK! It looks as if I have generated some interest and possibly some approval in my new smoke system. I am sort of over taxed at present with holidays and all, but I will in the next few days try to post some photos and information on this system. I have somewhat departed from the norm and feel the results are very worthwhile. Anyone that is interested in a smoke system should take a serious look at this as it has many advantages over what is currently available commercially. Best Regards and Happy Holidays to all, Allan
I AM VERY INTERESTED IN YOUR SYS. OR AT LEAST THE NOOOZLES. PLEASE CONTACT ME AT 936-443-3562 THX DENNIS MCCRIGHT RV-6 COMPLETE, RV-8 UNDER CONSTRUCTION.
Old 01-16-2011, 08:35 AM
Smile
I AM VERY INTERESTED IN YOUR SYS. OR AT LEAST THE NOOOZLES. PLEASE CONTACT ME AT 936-443-3562 THX DENNIS MCCRIGHT RV-6 COMPLETE, RV-8 UNDER CONSTRUCTION. denmacaero@gmail.com
Old 10-06-2013, 06:10 AM
Capflyer's Avatar
Capflyer Capflyer is offline
I decided on this design after quite a lot of experimentation with different spray patterns. Anything will work but the finer you can atomize the oil the better the smoke Having one hole is easier to make and control than multiple holes. The stream contacts the wedge and fans out to 180 Deg. spray pattern that for me worked better than all others I tried. You ask about moving the nozzle further up the pipe and it doe's work but produces a very different looking smoke pattern. The smoke resembles a giant string of pearls in the sky from each pipe. The reason for this is very simple, the four stroke engine only duplicates an exhaust cycle once every 720 deg. of rotation. This exhaust valve opening lasts aprox. 210 deg. of which only 100 deg. is effective exhaust flow that can evacuate the pipe. The smoke system is injecting oil into the pipe continuously so 1&3/4 rotation of the engine the pipe is being charged with oil and only being expelled about 12% of the time thus producing the puffing or smoke balls. The more cylinders you have working on the oil spray the more and smoother the smoke. If you are interested I can send you a link to the stainless spray heads I started with to produce my nozzles. The pump you were going to use should work very well as they are a quality unit designed for petroleum products. I am not a fan of using a water pump intended for a camper to pump flammable liquids ether. Thank you for your interest, Allan
Allen, you had some good information in this older thread. I am looking to replace my homeade nozzles with something off the shelf. I'd be curious to see your results from trying different nozzles. I noticed that even SA is now using an off the shelf nozzle but I can't tell what orifice size it is from looking at it (my buddy purchased their kit) but it definately looks to be a 40deg fan spary pattern. Not that I need to find this exact one but real world experience from others would help make a decision.
If anyone else has had success with different nozzles I'd like to see that info as well. Lots of places sell nozzles including Grainger which is just down the road from my house.
Mike
JAMES AIRCRAFT.com
Flying - RV8 Hot Rod "Drone Killer"
Flying - RV8 "Look'n Good"
RV4 - FAST & FUN! Rebuilt, Flown, Sold
RV-7A Built, Flown, Sold
Old 10-06-2013, 07:13 AM
jim plaster jim plaster is offline
Default Anti splat aero
Allen, I've got many of your products on my RV6 now and love them all! If I didn't have a SA system already I'd certainly look at yours. Keep up the good work over there and keeps us posted on any new products! Thanks ...jim
