Originally Posted by hevansrv7a
Please see embedded questions. Not arguing, seeking to understand.
The same is true for multi-blade props because for a given diameter, a three-blade prop will have 50% more mass flow.
(Doesn't this assume equal blades area, shape, CL, etc., which would not be feasible?), so less energy gets thrown away in downwash.(But aren't longer blades better for induced loss, if all else is equal?)
Mass-flow should not be confused with blade area. Lift, or thrust, is the product of area, Q, and CL. If you have more blades, you reduce the area on each blade by the ratio of the number of blades, but you keep the CL the same, so the overall thrust is the same. Induced loss is a function of mass-flow which has to do with disc area, which is what was stated in the first sentence. If you keep the diameter the same and increase the number of blades the mass flow goes up, the downwash, which has to do with induced loss, goes down, and the efficiency, at least at low speed, goes up. The latter is true since at high speed the delta-v only contributes a very small portion to the mass flow since most of it comes from forward speed. That is why a multi-blade prop has better static thrust and its attendant better take-off and climb, where speed and mass flow are low.
It's unfortunate that in the aviation community the mis-conception that multi-blade props aren't as good in cruise as a prop with fewer blades was based on the fact that the aerodynamic shape of the blade roots at that time contributed so much drag to the overall plane's drag; more blades, more drag. Unfortunately, the "experts" attributed this to some mythical "tip loss" fuction, and every one nodded their heads in affirmative unison and repeated "I see, I see!".
Even with Tom Aberle dominating the biplane races with a four-blade prop, the skeptics still attribute this to enough engine power to overcome the supposed multi-blade drawback. Just look at the 8-blade props on the A-400M, the same on the new C-131J, and the 18 to 24 blade fixed pitch fan (prop) in the front of a jet engine. Are these designers laboring under some delusion? It is time for the aviation community to put this misunderstanding to rest!
