Old 01-05-2011, 08:13 AM
swixtt swixtt is offline
i didn't think these iPad had GPS 'built-in'?? the only option is with network or not.
RV9.... Tail done. Inspection done! Wings pre-cover MDRA inspection done. Closing them up now. Fuse underway.
Old 01-05-2011, 08:45 AM
pierre smith's Avatar
Default There are several versions of the iPad Pete..
....and I have the 32 Gig non-GPS version, since I have a 496 and 430W in the airplane.
The 3G version costs an additional $100 and has its own internal GPS and a moving map.
Best,
Pierre Smith
RV-10, 510 TT
Air Tractor 402 PT-6-20 Sold
Louisville, Ga
Patrick Kenny, EAA 275132
Dues gladly paid!
Old 01-05-2011, 09:26 AM
agough277 agough277 is offline
Default Gizmos
Be careful with all those electronic devices. One nearly caused a friend to crash when a stylis was lost and jamed the controls. Not an RV.
RV6A, RV7, RV6 Wing
Living with my 6A at 3L2 near Las Vegas
Old 01-05-2011, 09:34 AM
so the 3G has the GPS built in? can you buy one with GPS but no 3G? i thought there were only a couple varieties.
i got one for my dad but it did not have any network services other than wifi
Old 01-05-2011, 10:40 AM
craigvince's Avatar
craigvince craigvince is offline
All the 3G models have the GPS chip built in. You don't need to subscribe to the 3G service for the GPS to work.
Old 01-05-2011, 12:32 PM
erich weaver's Avatar
YES.
NO, but you can buy one with no 3G and no GPS and then buy the blue tooth GPS add-on from Craig. Cheaper to just buy the 3G/GPS capable iPad I think, but the add-on bluetooth GPS may provide a better/more reliable fix.
Craig, can you comment on this?
erich
Old 01-05-2011, 12:39 PM
thanks guys for the clarification!
Old 01-05-2011, 01:34 PM
odlee odlee is offline
Default This is for what it is worth comments.
At OSH Foreflight felt the internal gps was not reliable enough for locating the moving plane on IFR charts. No mention was made of the compatible (and portable) gps units we now see available, which they now support on the enroute charts. I have not inquired about the approach plates.
I did not discuss this with other vendors.
David
Old 01-05-2011, 01:38 PM
craigvince's Avatar
The bluetooth GPS receiver is a WAAS capable unit and is much more accurate than the built-in GPS chip on my iPad.
That said, I haven't had any issues with 10m accuracy without vs 3m accuracy with the new unit. 10m is close enough, I suppose. I have played with my bluetooth inside my house and still get 5m accuracy even indoors, not that I need a GPS indoors, but it is a very strong receiver.
