Go Back   VAF Forums > Avionics / Interiors / Fiberglass > COMM
Old 01-03-2011, 11:01 PM
Jeff A's Avatar
Jeff A Jeff A is offline
Question Do you have a standby PTT switch?
Just curious how many of you have installed and/or needed a standby (secondary) PTT switch. I have the Infinity grip upfront (RV-8) and was wondering if I should install a small switch elsewhere in case of failure. Thoughts?
Jeff Atkinson
RV-8 #82594 Flying since May 2012
Barrett XP-360, Catto 3-Blade, Dual G3X Touch, GTN-650, VP-X
Old 01-03-2011, 11:32 PM
erich weaver's Avatar
I put a PTT button on right side stick on my 7A. Didn't really think of it as a backup at the time, but now that you mention it...
Very cheap and not much trouble. Why not?
Erich
Old 01-03-2011, 11:39 PM
RV7AV8R's Avatar
RV7AV8R RV7AV8R is offline
I have a PTT on both sticks of my RV7. On one occation my left PTT failed and I had to use the one on the right stick. It took me a few seconds of stress to realize that in order for me to talk and listen with that PTT switch I had to plug my headset into the right seat outlet as well. I did that and it worked!
John Adams
Seattle
RV7 600+hrs
Paid 12/2014
Old 01-03-2011, 11:42 PM
MontanaMike MontanaMike is offline
Default Standby PTT
I installed a co-pilot PTT in the lower right panel so my passenger stick could be removed in my side-by-side 6.
Twice in cold weather my pilot ptt has intermittenly failed to work and I switched my headset to the right side/ptt and carried on. It really @@@@@@ you off when that happens and without an alternative I would have been held up in remote areas.
Still trying to duplicate the problem on the ground...no joy.
My 2 cents.
Mike Bauer
RV6 N918MB
Old 01-03-2011, 11:48 PM
RV7AV8R's Avatar
Mike Bauer
RV6 N918MB
Mike, Interesting that I could not determine a cause either and my next flight the left one worked fine and has ever since. Since we have both had a problem I would definitely install a second PTT switch in an RV8 where you can not get to the rear PTT.
John Adams
Seattle
RV7 600+hrs
Paid 12/2014
Old 01-04-2011, 12:09 AM
PCHunt PCHunt is offline
Would an old-fashioned hand mike with a push-button work as an emergency backup
Pete Hunt, [San Diego] VAF #1069
RV-6, RV-6A, T-6G
ATP, CFII, A&P
2020 Donation+, Gladly Sent
Old 01-04-2011, 12:10 AM
Bill Palmer Bill Palmer is offline
Default Panel PTT
For my 8A, I have a panel PTT switch as a backup for my grip switch and as a primary PTT if I'm on autopilot and don't want to touch the stick.
Good Luck!
Bill Palmer
Old 01-04-2011, 12:54 AM
RV7AV8R's Avatar
It could but only if the "mike" phone jack was wired for the PTT switch in the hand held. This probably is rarely done in planes set up for head sets.
John Adams
Seattle
RV7 600+hrs
Paid 12/2014
Old 01-04-2011, 05:35 AM
RV6_flyer's Avatar
Backup PTT (Push Then Talk) on each arm rest. The pilot not flying can do the radio work without touching the stick.
Ditto, Rosie
Gary A. Sobek
NC25 RV-6
Flying
3,400+ hours
Where is N157GS
Building RV-8 S/N: 80012
Old 01-04-2011, 08:29 AM
DeltaTango's Avatar
DeltaTango DeltaTango is offline
I installed a second PTT on the upper left corner of my panel. I use it when someone in the back is flying or on autopilot. I have also used it when my stick mounted PTT starting acting up. All fixed now, however I was glad that I had the second switch.
David
RV-8
