Old 12-29-2010, 02:57 PM
pierre smith's Avatar
Default My EGT's have risen 100 degrees!!
...during the last two flights. After balancing the injectors up at Airflow, everything was cozy and I happily ran 50 LOP with EGT's around 1420 or so. All of a sudden, they're reading 1560 and the numbers turn yellow on the D-120. In the past, the hottest they'd get was around 1460-1470, then start dropping going LOP.
Methinks I have a couple of bad probes since only two cylinders do this while the others are 125 deg cooler. They're three years old with 350 hours on the airplane.
What say you?
Pierre Smith
RV-10, 510 TT
Air Tractor 402 PT-6-20 Sold
Louisville, Ga
Patrick Kenny, EAA 275132
Dues gladly paid!
Old 12-29-2010, 03:12 PM
Sig600 Sig600 is offline
Fuel flow and CHT's still consistent with what you're used to seeing? May be bad probes, however if you're seeing this immediately after balancing the injectors..... ??? One EGT probe going I could see, however two at the exact same time? I'm no math major but statistically that's a stretch.
Next?, TBD
IAR-823, SOLD
RV-8, SOLD
RV-7, SOLD
Old 12-29-2010, 03:45 PM
sjarrell sjarrell is offline
What are your CHTs? Did they go up as well or are they normal?
Steve Jarrell
Building RV-14A QB "Freedom"
N614US (June 14 - Flag Day)
Dues Paid - Gladly!
Old 12-29-2010, 04:07 PM
AlexPeterson's Avatar
Seems like one plug in those high egt cylinders is not firing. If one plug stops firing, it is somewhat like retarding the timing.
I know if I turn one ignition off, the egt's go way up also.
Alex Peterson
RV6A N66AP 1700+ hours
KADC, Wadena, MN
Old 12-29-2010, 04:54 PM
asav8tor asav8tor is offline
BINGO!!!!
Old 12-29-2010, 07:24 PM
airguy's Avatar
airguy airguy is offline
Possible induction leak? Is your manifold such that you could have a leak that would only affect those two cylinders driving them leaner? Do they all still hit peak at the same fuel flows as before?
Old 12-29-2010, 08:23 PM
aerhed aerhed is offline
Restricted injector (dirt) would make EGT go up normally, but maybe not when LOP. Fuel flow would maybe stay the same with "lost" fuel from the 2 restricted injectors going out through the other 4 cylinders. That would change CHT's & EGT's on the other 4. LOP is almost like region of reverse command. Do your temps & fuel flow indicate this?
Actual repeat offender.
Old 12-29-2010, 08:34 PM
NDrv8r's Avatar
NDrv8r NDrv8r is offline
Default probes
If memory serves, I think probes generally fail lower rather than higher. Does any one else have any thoughts on that?
Larry Buller
RV7A slow build, Tip up, IO360 200hp, Catto 3 blade, Dynon Skyview, arinc 429, ems, SV transponder, Garmin GNS430w, Aera 560, Dynon D6.
FLYING!
Old 12-30-2010, 05:34 AM
Default The mag checks good...
...during runup and so does the Lightspeed.
The CHT's on those two cylinders are also close to the others and cooler than a couple as well. The cowl's coming off today for a closer look...maybe it's whispering in my ear, huh?
Pierre Smith
RV-10, 510 TT
Louisville, Ga
Dues gladly paid!
Old 12-30-2010, 08:01 AM
Pierre - is it possible that the two cylinders are both on the same Lightspeed coil? If so, that coil might be flaky. Since it is a wasted spark system, each coil fires two cylinders.
Alex Peterson
KADC, Wadena, MN
