Go Back   VAF Forums > Model Specific > RV-9/9A
Old 12-20-2010, 07:06 AM
Kokemiller's Avatar
Kokemiller Kokemiller is offline
Default Retracting flaps after landing
Just wondering how many of you make it a standard practice to retract the flaps as soon as you touchdown. I know it reduces aerodynamic braking and wouldn't be good practice on short field landings but it does have some good advantages:
1. Makes it easier to keep the nose off longer (don't notice this in the 7A but it makes a big difference in the 9A)
2. In case of a go around the flaps are already up
3. Less debris beating up the bottom of the flaps
4. Reduces chances of gusts making you airborn again.
5. Increases braking effectiveness as less lift puts more weight on tires.
Kelley Kokemiller
9A sb N94KK 400hrs. and counting
Barrett O-320
Catto 3-blade
Panther tail complete
Old 12-20-2010, 07:35 AM
matt matt is offline
I do a lot of short field landings on strips and for me dumping flaps is standard practice.
Not only because I get a lot of paint chips in the flaps if I don't: My ground roll is greatly reduced; I can apply brakes in a way more aggressive way.
jm2c as usual..
RV-4, O-320, FP
CFII/MEI & dreamer
Old 12-20-2010, 07:48 AM
Mel's Avatar
Mel Mel is online now
Actually the addition of brake effectiveness outweighs aerodynamic braking at landing speeds. My home strip is 1500' and is considered short by many. I ALWAYS dump flaps immediately on touch down. And as you say, it also reduces the probability of going airborne again.
RV-6 Flying since 1993 (sold)
<rvmel(at)icloud.com>
Old 12-20-2010, 08:00 AM
unqualified unfluencer
Thumbs up Yes.
...I'm a manual dumper (so I can make the bravo turn off by where I hangar).
Doug Reeves (your host)
Old 12-20-2010, 08:44 AM
Ron Lee's Avatar
Ron Lee Ron Lee is offline
I don't. I am concentrating on keeping the nose wheel off the pavement then slowly letting it down. I minimize braking and am not usually hard on them to get off at any specific turnoff. Once I turn off I usually raise them to minimize the chance of debris damage. Note sure that it is a big hazard with wheel pants.
Old 12-20-2010, 09:13 AM
Mel's Avatar
Flaps tend to push the nose down. It is easier to hold the nose up with the flaps retracted.
Old 12-20-2010, 09:15 AM
Mike S's Avatar
Mike S Mike S is offline
Senior Curmudgeon
What Mel said
Mike Starkey
VAF 909
Rv-10, N210LM.
Flying as of 12/4/2010
Phase 1 done, 2/4/2011
Old 12-20-2010, 09:17 AM
Vern's Avatar
Vern Vern is online now
Default Raising flaps after a landing-Yes
...but for a different reason. Having had the famous flap motor quit working happen a time or two, I want to know the flaps are up while taxiing IN, rather than while taxing OUT with baggage and pax loaded for flight. It's just one less hassle.
Vern Darley
Awarded FAA "The Wright Brothers 'Master Pilot' Award"- for 50 years safe flying
RV-6A N680V / RV-10QB N353RV
Luscombe 8E N2423K 50+years
Hatz Biplane N2423Z soon to be birthed
Falcon RV Squadron Founder
KFFC Hanger D-30
Peachtree City, Ga
770 310-7169
EAA Technical Counselor #5142
EAA Flight Advisor #486336
ATP/CFI/A&P/DAR
Old 12-20-2010, 09:39 AM
Capflyer's Avatar
Capflyer Capflyer is offline
While I don't disagree with retracting the flaps on the landing roll out on a short field landing which is proper technique, if any of you fly with a CFI and in a retractable gear plane, don't be surprised if you get your hand slapped while retracting the flaps on roll out.
Mike
JAMES AIRCRAFT.com
Flying - RV8 Hot Rod "Drone Killer"
Flying - RV8 "Look'n Good"
RV4 - FAST & FUN! Rebuilt, Flown, Sold
RV-7A Built, Flown, Sold
Old 12-20-2010, 10:05 AM
videobobk's Avatar
videobobk videobobk is offline
The flap switch is the first thing I hit when the wheels are down. Makes it easier to keep the nose up, allows it to stay up longer, and still lets the nose down easy. With the nose up, the aerodynamic braking is fine. Also, with the 9, having the flaps up protects the wing/flap joint as you enter/exit. I am always afraid of someone stepping on that back two inches of the wing (not the flap) and damaging it. Fixing a flap is easier than fixing a wing.
Bob
Bob Kelly, Scipio, Indiana
Tech Counselor
Founder, Eagle's Nest Projects
President, AviationNation, Inc
RV-9A N908BL, Flying
