12-16-2010, 11:14 AM
Master Relay Recommendations Sought
Hi,
I'm making some upgrades to the electrical system in my -4 and am looking for a new master solenoid (40amp, continuous duty). I've looked in the usual places, but haven't found much of a selection. Can any recommend a part? So far, I have found only 1 option in Aircraft Spruce - nothing at either Steinair or Aeroelectric.
Dean
Bolton, MA
12-16-2010, 11:20 AM
Walt Aronow, DFW, TX (52F)
EXP Aircraft Services LLC
12-16-2010, 11:26 AM
I am using these from The Drill Spot,,,,,They have a great selection and good pricing. Also available in 24V which I am doing. http://www.drillspot.com/products/44...power_solenoid
David C.
Howell, MI
12-16-2010, 08:47 PM
Van's sells the standard master relay. You can call them and order directly.
I assume you are running an O-320? The 40A seems quite low, considering it needs to carry the starter load.
Marc Ausman
RV-7 980 hours, IO-390, VP-X (sold)
RV-8 (flying a friend's)
Thinking about low and slow backcountry build.
VAF Advertiser - Aircraft Wiring Guide
Book to help with experimental aircraft wiring.
12-17-2010, 05:59 AM
Originally Posted by Walt
yup.... That is the one. It is also an upgraded one from stock.
12-17-2010, 10:20 AM
Here is the link....
Dave & Trina
RV-9A Flying  - 330 Hrs. Painted  Finishing the interior.
12-17-2010, 10:23 AM
Echlin ST-80
The master solenoid in our RV-6 was a Cole-Hersee 24115 (85 amp continuous rating). When it failed, we replaced it with an Echlin ST-80 (80 amp continuous) from NAPA, which has been working fine. Just another possible option to consider.
--Paul
12-17-2010, 03:19 PM
Great leads...
Thanks for all the leads. Very helpful
I'm running an IO-360, but have my system configured such that the starter current does not go thru the master solenoid. I have a dedicated starter solenoid that carries the all the starter current (and nothing else).
Thanks again,
12-19-2010, 02:22 PM
Thanks again,
Got it. Normally the starter solenoid is wired in series with the master solenoid so that if the starter solenoid sticks closed you can disengage the starter by turning off the master switch.
Marc Ausman
12-20-2010, 09:07 AM
Dean, there is a Bosche relay, # 0 332 002 150 you may want to take a look at. Its designed for Fork Lift trucks. It runs up to 400amps for > 1 sec, which is more than we need.
Its very compact. It looks unlikely 'til you read the spec. I was introduced to it by the Aviat Husky community.
