Old 11-13-2010, 09:54 PM
JDanno JDanno is offline
Default IPad GPS dongle
Have you seen the new dongle for the IPad, IPod,IPhone that is a high quality GPS device that plugs into the 30 pin hole. Suppose to GREATLY enhance the GPS capabilities of these three devices. The app is free from the Apps store.
I'm thinking that this is what we have been waiting for to increase the capability of our IPhone and IPad devices to where they can reliably used for onboard navigation. It even has WAAS capability. Check out the web site or the app site. Www.bad-elf.com
No jailbreak required and look at the blog page as the owner is a pilot and has
a blog about it. This should enhance the use of the IPad as the gps built into it is kind of sketchy in my humble opinion.
It's on sale now for $99. Install and download the app.
Old 11-14-2010, 07:06 AM
hevansrv7a's Avatar
hevansrv7a hevansrv7a is offline
Default BlueTooth GPS
I have a BlueTooth GPS that works well with my old HP PDA. Will it work with an iPod/iPad? Anyone who has one and knows? Thanks.
H. Evan's RV-7A N17HH 240+ hours
We can lift ourselves out of ignorance, we can find ourselves as creatures of excellence and intelligence and skill. We can be free! We can learn to fly!" -J.L. Seagull
Paid $25.00 "dues" net of PayPal cost for 2015, 2016, 2017 and 2018 (December).
This airplane is for sale: see website. my website
Old 11-14-2010, 07:27 AM
pierre smith's Avatar
Default It appears to make a non- GPS unit into a....
...unit that is now a GPS unit, if I read the site correctly.
Yes/no?
Best,
Pierre Smith
RV-10, 510 TT
Air Tractor 402 PT-6-20 Sold
Louisville, Ga
Patrick Kenny, EAA 275132
Dues gladly paid!
Old 11-14-2010, 07:49 AM
seattlebuoy seattlebuoy is offline
See foreflight blog or AOPA forum for more info onthe bad-elf GPS for iphone/ipad.
Old 11-14-2010, 08:12 AM
LeeM_2000's Avatar
LeeM_2000 LeeM_2000 is offline
That looks a little bit cumbersome to me. I wonder if one of these Garmin Bluetooth GPS receivers can't be adapted:
Old 11-14-2010, 08:20 AM
Cumbersome?? I don't know as it's about the size of a pack of matches. Maybe a "large" pack of matches. :-) I've got one ordered so I'll soon find out. That said, I don't much like things hanging out of the IPad to catch on things. Also with a plastic top on my -10 the reception should be unaffected.
The other receiver GNS 5870 also looks interesting as it can be remotely located and powered. It looks to be about $150 (119.00 Euro).
Old 11-14-2010, 08:45 AM
rwhittier rwhittier is offline
Default Yes
Saw the FF booth at AOPA and the Bad Elf unit. It is a very good solution for those of us the have the WiFi only iPad. One of the guys there said they plugged it into the iPad on the commercial flight to the Summit. Locked on is seconds and had a great signal at almost 500 knots. That should suffice for the RV
Yes/no?
Best,
Roger Whittier
RV7A Quick Build, Tip Up
N1MY Reserved - Canopy finished - Wings mated, Engine hung, electrical 95%
Old 11-14-2010, 09:31 AM
jcaplins's Avatar
jcaplins jcaplins is offline
I though the ipad could just be rotated and the screen orients itself? Therefore putting the GPS at whatever position you desired; top, bottom, left or right.
Jeff Caplins
California
RV7 N76CX
(started: Feb 2002 --> Completed: May 2016)
Old 11-14-2010, 10:49 AM
Sure it does, and you can lock it in your desired position. Sometimes it's better to have a landscape orientation and sometimes better to have a portrait orientation.
Old 11-14-2010, 11:48 AM
Wastah Wastah is offline
Default Ipad GPS
Flew with the Ipad, Bad Elf GPS unit today. Worked well and more accurately although I Need to use it more to figure out how good it is. I unplugged it after a bit as it really takes a lot of power. I'm ordering a plug in 12 volt power supply which will connect to the GPS unit with a mini USB and charge the Ipad while it is being used. Having a wire hooked up I think will be a drag but would be necessary for a very long trip using the GPS unit. I think the Ipad would work well on a Knee board. Also got a capacitive stylus which is much better on the "scratch pad" than trying to take a clearance with you finger as the writing instrument.
Wastah
