View Poll Results: Now that the RV-12 is out the door, what should the next RV be?
Nothing for now - focus on efficiency, cut costs and prices, survive. 209 30.20%
A factory-built version of the RV-12 36 5.20%
The RV-11 Motorglider 120 17.34%
An amphibian 54 7.80%
An updated single-seater 111 16.04%
A twin, using the new IO-233 or Rotax engines 71 10.26%
A turboprop 36 5.20%
A jet! 55 7.95%
Voters: 692. You may not vote on this poll
  #101
Old 10-18-2010, 06:08 AM
Bob_pipedream Bob_pipedream is offline
Here are a few ideas (probably already stated in this thread):
Revisit the cowl design and try to lower the cooling drag by creating some kind of lower cowl baffling that would also stop floor vibration in 6,7,9 and improve efficiency
Redesign the 6,7, 8 and 9 nosewheels
Sort out documentation - particulary for older models - e.g. air dams in baffle plans for 7 and 9 apparently, but how would a 6 owner know about that? (just stick something on the Vans website)
Yep that glider would be cool - preferably electric and maybe with solar panels on the wings
Do a study on the RV6 and maybe increase max load (just 50lbs would be good)
Do long range tanks
Investigate a modified monkeybike (50-100cc cable of 45mph and can use Avgas from the tanks) that could fit in a RV6,7,9 (would have a big market for that - 500 - 1000 owners would want one)
Produce a taper wing retrofit (not sure would be much more efficient but would look cool)
Finally how about guns?
Old 10-18-2010, 07:30 AM
rhill rhill is offline
Default Fix the Nose wheel
Not since the RV-3 wings would fail in flight and the 3B wing redesign, Has Vans had a such a Moral Hazard as the 6,7,8,9 A nose wheel. Regardless of how it happens, who is at fault, Pilots, Vans, Gofers, It does happen and far too often.I would like to see a stronger nose gear to address this issue. Who better than Vans to do this, I can't think of a better time than right now for the company.
Old 10-19-2010, 04:59 AM
Agree with the nose wheel issue...
But what about a pressure recovery fuselage for the RV8?
Old 10-19-2010, 07:58 AM
bhassel's Avatar
bhassel bhassel is offline
hmmm... realistically - what base doesn't Van's have covered. Everything is there except maybe a niche market (no harm in that)! How can we help keep Ken et al busy? Maybe just upgrades to the current line.
  • A new nose wheel option for those that want it (I'd like to think I'm going tail dragger if I can ever get back to the project again!)
  • Extended range tank option for all models
  • RV-12 style panel option for those that want it
  • An improved golf swing (everyone needs one of those)
Bob
Bob Hassel
NM
Subscription Paid for 2020
Home is where the hanger is...
Old 10-19-2010, 08:11 AM
Stabird Stabird is offline
Default Nosewheel, Nosewheel, Nosewheel, Nosewheel.
How many rollovers before a death and lawsuite shuts down Van's? Apply the resource to improve the "A" nose landing gear design.
Old 10-19-2010, 09:09 AM
Danny7 Danny7 is offline
what statistics do you have to back up your claim? If you say it happens way to often i'd like to see a little statistical comparison of rva models flying, vs ones that have flipped or had a nose wheel incident. I know statistics can be made to show things you want, but i'd like to see people that make a claim have some number, any number; an actual number of incidents to say there have been to many.
nothing special here...
Old 10-19-2010, 10:02 AM
Kitplanes, July 2010, article starting page 36.
Old 10-19-2010, 10:36 AM
Andy Hill's Avatar
Andy Hill Andy Hill is offline
If you want a "true" nosewheel aeroplane, buy one - not a "converted" taildragger That is what A stands for...
Whilst the rollovers are hardly desirable, I do not think they are a significant safety hazard, given that Van's effectively say to keep the NW off the ground. As per the post above, yes - they do have a number of high profile accidents, but are they actually more hazardous than the taildragger version?
Andy
Old 10-19-2010, 12:32 PM
redwards redwards is offline
How about writing some decent building instructions for the existing models?
Randall L. Edwards
RV7A slider
working on firewall forward
Old 10-19-2010, 01:43 PM
tomcostanza tomcostanza is offline
Fix the nosewheel.
Tom Costanza
RV-7A Fuse
