  #171
Old 10-04-2010, 05:43 AM
Default lessons
Guys, All of these comments are great lessons learned, and I will study them all, since you have gone through is before. Guess I need to really look at my abilities, and what lies ahead. I heard someone say something about "repeat offender". I guess I could do that ---maybe
Tom
Ridgeland, SC
Old 10-19-2010, 06:55 AM
maximillion maximillion is offline
Default 7a or 9a?
Come of guys help me make my decision, 7a or 9a. Was dead set on the 7a but things are brewing.............
Old 10-19-2010, 06:59 AM
rv9aviator rv9aviator is offline
The two things that made up my mind were These:
If I remember this right, the guys at Van's said they liked flying the 9 on cross country flights better than any of the others because of the different wing airfoil. They said it was smoother and actually a little faster at altitude.
I don't do acro.
I plan on using my plane for trips with the wife so it was an easy decision.
Jim Wright
RV-9A N9JW 90919 SoldArkansas
http://www.jimsairplanes.com
_______________________
"It's a brutal struggle for the biscuit."
Old 10-19-2010, 07:07 AM
zspivey's Avatar
zspivey zspivey is offline
Default 9A vs 7A
If you are considering an RV there is no wrong answer. Any choice is a good one. The 7 will allow acro; the 9 is better for cruising. Define your mission, then make your choice.
When I was building the RV8A, I thought I would be doing acro on every solo flight. I did less that a dozen rolls and less than 6 loops. Since I sold the 8 and bought the 6, I have done only 2 rolls and have never looped it.
The 6 is a great airplane. I think a 9 would fit my mission better.
Zack Spivey
VAF #459
Ruston, Louisiana
RV-8A Built, Flown, Sold
RV-6A Purchased flying, Flown, Sold, Now Planeless
Old 10-19-2010, 07:54 AM
7AlphaMike 7AlphaMike is offline
The 9a is a great airplane. But you realy cant go wrong with any "RV".
The 9a is the choice if you're not doing acro, and those low end numbers are realy great. Don't worry about sacrificing sportiness with the 9.
Old 10-19-2010, 08:45 AM
IowaRV9Dreamer's Avatar
IowaRV9Dreamer IowaRV9Dreamer is offline
I chose 9A for x-c. I also like the longer/slender wing (more efficient at altitude). Looks more impressive on the ramp to me. I also like the idea of landing slower, especially off-field if ever needed (sure hope not).
I flew a 6A and 9A (never flew a 7A but similar to 6A). I found the 9A a bit more to my taste - still plenty "sporty" but a little less touchy.
Try to fly both and then decide.
Dave Gribble VAF #232
Building RV-9A N149DG (slider, IO-320, IFR)
Restored and Flying Beech Super III N3698Q
Marion IA
Struggling with fiberglass
There is no sport equal to that which aviators enjoy while being carried through the air on great white wings." Wilbur Wright, 1905
Old 10-19-2010, 08:50 AM
airguy's Avatar
airguy airguy is offline
The biggest difference between them is the 7(A) is made for acro and is slightly less efficient for crosscountry, where the 9(A) has the more efficient cruising wing that is happy up high.
I chose the 9A because I don't plan on doing acro, but I do a LOT of long crosscountry flying and I'm an efficiency freak.
Old 10-19-2010, 08:52 AM
bkilby's Avatar
bkilby bkilby is offline
It's like a porsche vs. a camry. Definitely go with the 7A.
Brian Kilby
flying RV-6A, previously flying RV-9A
based at KCTJ, Carrollton, GA
Old 10-19-2010, 09:19 AM
Chino Tom's Avatar
Chino Tom Chino Tom is offline
One thing to consider is the 42 gal of fuel in the -7 compared with 36
in the -9. That's an additional 1 hr with the same 160 hp engine. Most install
autopilots if they fly a lot of cross country. Not to mention larger engine
option of the -7. I've never flown a -9 but have flown -4, -6, -7 and -8 all
with basically the same wing. The -7 was a O-320 powered with
a constant speed prop and was IMHO the nicest flying RV I've flown.
Tom Prokop
Chino, CA
RV-8A,180/CS/Carb, AFS 4500 EFIS/EMS
RV-6, sold, 820 hrs of fun.
Old 10-19-2010, 09:28 AM
PerfTech's Avatar
PerfTech PerfTech is offline
Default "A NO BRAINER"!!!!!!!!!!!
If you don't do acro, This is a "no brainer"!!!!!!
The 9 is a better choice in virtually every other respect. It is just as fast at altitude (Mine trues @ 197MPH), rides better, climbs better with less H.P., has more useful load, tolerates higher density altitude, lands shorter, and with all of these advantages it may also save your life in an emergency off field landing. With it's much lower touch down and stall speed (44MPH) your chances of survival go up by over 50% per 10 MPH. I fly many hours a month in my 9A, approximately 70 and consider my exposure high. The above stated performance should be considered by anyone who intends to travel and expose themselves and loved ones to potential flying hazards. No Acro? Go for the comfort and safety! Regards, Allan
