Old 08-31-2010, 09:08 AM
koda2 koda2 is offline
Default Seat Fabric
I decided to build my own seats (what was I thinking).
I am getting close to finishing and they look like they are going to work pretty well, but I can't seem to find any reasonably priced aircraft seat fabric that will meet the certs. Anyone have any suggestions for a source? (Maybe "reasonably priced" and "aircraft" don't belong in the same sentence.)
I did try several local upholstery shops to see if they would do the work, and the minute the word aircraft came out, excuses came out of the woodwork at Vne.
Dave A.
6A
Old 08-31-2010, 10:11 AM
midwest rv-10's Avatar
midwest rv-10 midwest rv-10 is offline
Default seat fabric
yea, call Abby at Flightline interiors... Problem solved
Old 08-31-2010, 10:13 AM
bkilby's Avatar
bkilby bkilby is offline
You don't need to meet any "certs" for seat fabric.
Brian Kilby
flying RV-6A, previously flying RV-9A
based at KCTJ, Carrollton, GA
cfiidon's Avatar
cfiidon cfiidon is offline
Default White Lie
Get samples of the fabric you want to use and do your own burn test. Search on line for the criteria.
Tell them the seats are for a boat.
RV-8 QB Titan ECi 191HP XIO-360
WW200RV Dynon D180 HS34 AP74
GNS430 SL30 GTX327 PS8000B Uavionix Echouat
"Pilots are alchemists... we turn gold into lead."
Old 08-31-2010, 10:22 AM
Default fabric
How 'bout a Recreational Vehicle?
The certs on the fabric I was referring to were the FARs and burn testing.
Dave A.
Old 08-31-2010, 10:30 AM
bkilby's Avatar
Dave A.[/quote]
Yeah, that's the same certs I was referring to as well. Your seat covering choice does not have to meet any certification. You could cut up old t-shirts and have your seats covered in that if you wanted to.
Brian Kilby
Old 08-31-2010, 10:55 AM
carolsyracuse carolsyracuse is offline
Default aviation fabric
The clarification that I think is needed is that in experimental aircraft you do not need fabric that meets the aviation standards. However, if you do want the certified and plan to use leather or sheepskin I know that
http://www.dipi.com/ supplies the certificate with their sheepskin and probably with their leather as well.
However, I think all leather and sheepskin would meet the standards.
Auto fabrics must meet the car manufacturers guidelines. Several years ago I contacted one of the rv seat cover suppliers mentioned a lot to request samples since I thought I would get the aircraft grade fabric. That particular one used auto fabric. You could contact the seat cover suppliers to see if they use aviation fabric. Most likely they would sell you fabric by the yard. If they are using auto fabric you probably would do better price wise to purchase it yourself.
Old 08-31-2010, 12:56 PM
Mike D's Avatar
Mike D Mike D is offline
Do a search for Allante, Rave, Symphony, or Ultraleather and you should find some good prices. Something from $12 to $30 a yard.
The difference in price has mostly to do with the durability. (number of rubs before damage)
All have some form of flammability resistance and toxic fume tolerance. But If your seats are on fire, you have bigger issues.
Michael Delpier
RV6A -O-320, fixed pitch, GRT Sport, 496
RV-10 - working on finish kit
Houston
Old 08-31-2010, 09:45 PM
aerhed aerhed is offline
Two materials are accepted on certified aircraft with no added flame retardant required. Leather & wool.
Old 09-01-2010, 10:26 AM
clevtool's Avatar
clevtool clevtool is offline
We use fabrics with the California Fire Test Rating. It is more stringent than the FAA regs. believe it or not. They are listed for nearly all commercial fabrics that you buy. There is also a 'double rub' rating that will let you know the durability.
Mike Lauritsen
Cleaveland Aircraft Tool
800-368-1822
www.CleavelandTool.com
mike.toolman (at) gmail.com
Like on Facebook - Follow on Twitter - See on YouTube
