Old 08-23-2010, 03:10 PM
MSFT-1's Avatar
MSFT-1 MSFT-1 is offline
Default Owls and other ideas
Over the last few months I have been using my airplane to commute on a regular basis. This means it sits outside a whole lot more than it used to. One of the bigger problems is birds sitting on it (mostly on the vertical stab) and cr*pping all over the place.
I have seen other airplanes with fake owls on them to scare other birds away. Do they work? Anyone have any actual experience with preventing birds from cr*pping all over your airplane?
thanks,
Bruce
Richmond, VA (KFCI)
RV-10 (520+ hours since first flight in Nov 07)
RV-8 (500 hours, sold Sept 07)
Old 08-23-2010, 04:09 PM
FresnoR's Avatar
FresnoR FresnoR is offline
Sorry, no answer to your question, but it reminds me of a comic I read the other day:
Rick from Fresno
RV-7A
The art to flying lies in learning how to throw yourself at the ground and miss.
Old 08-23-2010, 06:24 PM
sf3543 sf3543 is offline
Default I used to use
a rubber snake. It worked pretty good, but you need to move it around as often as you can or the birds get used to it and ignore it.
Good luck.
Steve Formhals
A&P, Tech Counselor & Flight Advisor
RV3B
RV8
Old 08-23-2010, 06:43 PM
Sig600 Sig600 is offline
Get a piece of foam tubing (like you used to find to protect your groin on a bicycle frame) and make a slit down one side so that it can hug the upper edge of the stab. Push tooth picks through and glue them in place. I made one of these to keep birds off my bosses old 58 Baron. Worked wonders, and if I was going to be there for a few days I'd just tape it down with some blue painters tape that wouldn't pull the paint up.
There are probably a bunch of people here that can come up with a better engineered product than me, but it worked like a charm.
Old 08-23-2010, 07:23 PM
Ironflight's Avatar
VAF Moderator / Line Boy
Fake owls? I have seen them used numerous times - and usually they are covered in bird poop.....
Paul F. Dye
RV-8 - N188PD - "Valkyrie"
RV-3B - N13PL - "Tsamsiyu"
Dayton Valley Airpark (A34)
http://Ironflight.com
Old 08-24-2010, 05:53 AM
Louise Hose's Avatar
Default The owl idea is flawed....
Owls are nocturnal and most pooping birds are out during daylight hours. Thus, I understand, the owl figures don't work as they are predators of the birds that concern you. Perhaps a hawk or eagle would do better. But, it sounds like you've been given a better idea.
Old 08-24-2010, 06:25 AM
n981ms's Avatar
n981ms n981ms is offline
I saw recent article where an owl was used on a Bonanza with a scarf around neck to blow in the breeze.
Maxwell Duke
Kitfox S6/TD/IO240/SteamIFR Built it
RV10 IO540/AFS5600x3 Bought it
CH750 O200/AFS5500. Built it with 7 friends. DAR-Vic Syracuse
Maule M7-235C Sold it(kind of miss it)
VAF paid 5/2017
Old 08-24-2010, 07:20 AM
bhassel's Avatar
bhassel bhassel is offline
Owls are frequently used on our flat roof tops out here in the desert southwest. Those roofs that have them seem to require less bird repair than those that don't.
We have the ocassional robins & sparrows and lot's large ravens, hawks, etc. so it seems to cover a cross section of birds.
Bob
Bob Hassel
NM
Subscription Paid for 2020
Home is where the hanger is...
sbal0906's Avatar
sbal0906 sbal0906 is offline
That should work. There's a bridge I walk under on my way home from work and the light fixtures have a steel mesh on top with metal spines sticking up. No bird poop there.
Cheers.
Shamit Bal
http://www.flyaroundthesun.com
RV-9A
Started on wings.
Winnipeg, Manitoba, Canada
Old 08-24-2010, 08:09 AM
Sid Lambert Sid Lambert is offline
I think owls are used to keep snakes away, not birds. Maybe it only works in the south.
Sid Lambert
RV-7 Sold
RV-4 - Flying - O-320 Fixed Pitch - Red over Yellow
