Old 08-19-2010, 11:37 AM
autoglide autoglide is offline
Default Forward baggage bulkhead access panel?
Thanks in advance for all replies. I'm considering an 8"W X 5"T cutout for access to rear of the radio stack which is on the left side of my panel. Currently the space is so tight & impossible to get to the connectors. Would a cutout of this size degrade the integrity of the bulkhead? Facing the bulkhead from inside the baggage compartment the cutout would be in the upper panel to the right of center. The bulkhead is currently covered up with an upholstered panel. My preference is to NOT have to rivet in a doubler with nutplates to accept an 8" X 5" panel to cover the hole...which would bring it back to the orig. strength. MB
Old 08-19-2010, 03:58 PM
Correction......size of opening will be 6"W X 4"T (if that makes any difference)
Old 08-19-2010, 04:35 PM
Chino Tom's Avatar
Chino Tom Chino Tom is offline
I didn't use a doubler, but did rivet nut plates and use .032 for the
cover (hinged at the bottom). My cut out was much larger than the
one you are planning. Probably the most common -8/8A mod.
Here is a thread along the same lines.
http://www.vansairforce.com/communit...ad.php?t=45285
Tom Prokop
Chino, CA
RV-8A,180/CS/Carb, AFS 4500 EFIS/EMS
RV-6, sold, 820 hrs of fun.
Old 08-20-2010, 06:08 AM
dav1111 dav1111 is offline
Super Moderator
Default RV-8 Baggage Access Panel
You might want to check out the RV-10 Tunnel Access Cover located at this website: http://www.airward.com/default.asp
Click on Van's RV-10 on the left hand side and the tab for the tunnel access kit will come up.
Russ Daves
Lubbock, TX
Proud to be a Veteran
N710RV - RV-10 Sold
N65RV - RV-6A Sold
N686RV - RV-6A Re-Built, Sold
N742PZ - RV-8 Co-Builder Sold
N-867RV -RV-7 Finish Kit
Old 08-20-2010, 06:49 AM
cholladay cholladay is offline
Mine is also much larger, probably about 6''X24". I can access the entire panel from the rear. I did place a couple of vertical supports for strengh and the cover goes back on with nutplates. 275 hours and countless times I said to myself " I am so glad I did that"
Chad Holladay
Heritage Airpark TE86
RV-8 N769CE Sold
RV-10 N529W flying
RV -8 Building
Old 08-20-2010, 08:09 AM
gpiney gpiney is offline
I have seen one -8 where the owner mounted the ATO fuse block and the pitot/static plumbing on the panel. When it dropped down - there it was. I will probably do the same. I 'sketched' mine out and it looks to be around 4x18",maybe a bit bigger.
Greg Piney
RV-8 2547
Empennage Done!
Beginning Fuselage Final Assembly!
(Tub finished, on to Landing Gear).
Old 08-20-2010, 08:29 AM
jferraro17's Avatar
jferraro17 jferraro17 is offline
Opulence, I has it...
I agree, and I've put a couple of the fuse blocks there too. I cut mine before I realized that the FastBack kit would allow extreme access tot he back of the panel, but I'm still glad I did it.
Joe Ferraro
DFW, VAF #17
SOLD
Old 08-20-2010, 01:16 PM
panhandler1956's Avatar
Default Me too
I have an access panel with double and I have a fuse block on there too.
See pic below:
Brent Owens
Columbus, OH
RV-8 'Contrary Mary' flying
N784DE S/N #82614
www.fixedwingbuddha.com
Follow me on Facebook
