Old 08-10-2010, 12:28 PM
LifeofReiley's Avatar
LifeofReiley LifeofReiley is offline
Yes, my Superior book states the same, I do not own any pubs from ECI.
Reiley
Retired N622DR - Serial #V7A1467
VAF# 671
Repeat Offender / Race 007
Friend of the RV-1
Old 08-10-2010, 12:51 PM
az_gila's Avatar
az_gila az_gila is offline
Exclamation IIRC...
Originally Posted by apkp777 View Post
.....pull the tappets from the body and soak them in solvent (use a magnet to extract them from the tappet body)....
Lycoming is quite specific about not using a magnet on the tappets...
Gil Alexander
RV-6A N61GX - finally flying
Grumman Tiger N12GA - flying
Old 08-10-2010, 01:07 PM
az_gila's Avatar
Smile My factory Lycoming...
Originally Posted by LifeofReiley View Post
I've seen one thick and one thin most of the time. Some A&P's will actually use a seaming plier to adjust the retainer for the very slight pressure you want here. I prefer not to bend around on the retainer.
...rebuild engine (new cylinders) came with no washers...
Are we mixing up old castings (and narrow deck) cylinders that were designed for the older style of retainers?
The old narrow deck cylinders I have in my hangar do not have the cast in boss under this retainer, and I believe a spacer was called out in this case, but I can't find my old obsolete parts manual...
Gil Alexander
Old 08-10-2010, 01:22 PM
FrankK90989 FrankK90989 is offline
Compare the ECI with the Lycoming clips .The ECI clips have a nasty crease just waiting to break.
And yes you might need a washer or two under the clip, (use your own judgment) the cyl head castings could be made better.
How much do these engines cost???
Frank Karasti
Hibbing, Mn
RV-9A
Flying--------->-
Old 08-10-2010, 01:26 PM
fstringham7a fstringham7a is offline
Default RE: Gasket Part # ?
It looks like I will be changing out the retainers as precaution.
Does anyone ....Gil.... know the part number for the Neoprene Valve Cover Gaskets.... ECi Titan IOX-360 .
Thanks in advance.
Frank @ 1L8 ...RV7A... Flying and Tracken (MT-RTG)
Old 08-10-2010, 01:27 PM
Frank... Now that was funny!!! Made me spill my soda.
Reiley
VAF# 671
Friend of the RV-1
Old 08-10-2010, 01:43 PM
az_gila's Avatar
Smile These should do it...
Thanks in advance.
RG-75906 for a parallel valve engine, RG-67193 for an angle valve...
http://www.aircraftspruce.com/catalo...calvecover.php
Gil Alexander
Old 08-10-2010, 01:46 PM
Default RE: Gasket # ???
Thanks in advance.
My research comes up with a part number ....75906
So... SL75906 @ 1.03
75906 @ 1.52
and at Chief
RG-75906 @ 6.75
I just need to call AERO and check to see what the gasket material is made of.
THANKS GIL>>>>>plus you are fast!!!!!
Old 08-10-2010, 02:38 PM
Default RE:Lyco or Superior
AERO is sending me new retainers. Thanks
Hi Tony
Is AERO sending you Lyco or Superior retainers.
The reason I ask is I called them today (Aug 10, 2010) and they said they were out of Lyco but would send out Superior which were sent to all that have called ......
Old 08-10-2010, 04:44 PM
apkp777's Avatar
apkp777 apkp777 is offline
Hi Tony
I don't know. As long as they aren't ECI ones I don't care.
Tony Phillips
N524AP, RV 9 (tail wheel)
