06-01-2010, 09:36 PM
Firesleeve for the Red Cube?
Hi everyone,
What diameter firesleeve are people using to wrap around the FT-60 red cube fuel flow sensor?
Craig Schwartz
RV-8 (Flying!), IO-360B1PC2 (180 hp, 1 P-Mag, 1 Slick Mag), Whirlwind 200RV, AF-3500, G496, Digiflight II, Classic Aero Sportsman Ultraleather Seats
N868RV
Santa Rosa, CA
06-02-2010, 03:29 AM
Hi Craig,
I used 64mm (2 1/2") ID firesleeve which worked well with a little room to spare.
Steve Hutt
West Sussex, UK
RV-7 G-HUTY (not flying yet)
( Tip-UP / TMX-IO-360-M1B / Hartzell 7497-2 / 1x LSE PLASMA III / Dual AF4500's / AF-Pilot AP / 695 )
06-03-2010, 11:34 PM
Hi.
I slit open a few lenghts of large diameter firesleeve (I think the diameter was about 1 inch) and wrapped them around the cube using safety-wire and clamps.
Then sealed all cuts with high temp RTV.
(This wasn't done when this pic was taken)
Seems to work well so far.
Regards Alf Olav Frog / Norway
First RV-7 completed, (bought partly finished from a US-builder) 305 hrs per July 2014, SOLD
Second -7 had first flight Feb 25th 2014. 220 hrs pr July 2019. Life is good!
06-06-2010, 10:24 AM
ao.frog, Re your photo, I have heard that tywraps on the powder coated engine mount will wear through the powder coating under the wrap.
John Adams
Seattle
RV7 600+hrs
Paid 12/2014
06-06-2010, 02:31 PM
Thanks for the tip regarding tywraps. I've heard the same thing.
It's a bit hard to see it but it's actually lacing cord on the pic...
06-07-2010, 08:05 AM
Sorry! By the way, I like your idea of multiple heat shields on the exhaust pipes. I think I will order some more for mine.
John Adams
Seattle
RV7 600+hrs
Paid 12/2014
07-15-2010, 04:35 PM
Firesleeve
Originally Posted by shuttle
Hi Craig,
Where can I buy 2 1/2" ID firesleeve???
I've looked at the usual places and they only have the smaller sizes.
Thanks in advance.
Bob Martin
RV-6, 0-360 Hartzell C/S, Tip up, 1200+TT
James extended cowl/plenum, induction, -8VS and Rudder. TSFlightline hoses. Oregon Aero leather seats.
D100-KMD150-660-TT ADI2- AS air/oil seperator. Vetterman exhaust with turndown tips.
Louisa, Virginia KLKU N94TB
07-15-2010, 06:35 PM
Big firesleeve
Bob
I ordered large diameter firesleeve from an industrial hydraulic supply company. They use a different name and its not TSO, but its much cheaper.
Matt
C-GVMK
RV9a Slow(ly) built
Flying as of July 2012
07-16-2010, 12:52 AM
Just finished this job. I used the 1.5" diameter sleeve from Spruce.(pricey) I slit it along the length, turned it 90 degrees and wrapped it around the cube. Secured it with a metal firesleeve clamp around the middle and tywraps at each end. I also used a short piece of small diameter sleeve at each end to cover the flare fittings. You will need to make a cut in each corner to allow the tywraps to pull the ends in snug.
I used the high temp permatex to seal the seams. This also firms it all nicely, and holds in any baggy bits.
I was surprised how well it worked out, I was anticipating a bit of a struggle!
Mind you, I haven't flown yet.
Jim Green
RV7 tip up
IO360 Whirlwind 200RV
07-16-2010, 06:39 AM
64mm (2.5") Firesleeve
Hi Bob,
Here's the Ebay item I bought. It's in the UK, but hey, transatlantic purchasing works.
I've bought and shipped 99% of the parts for an entire RV-7 from the US to the UK
http://cgi.ebay.co.uk/64mm-Firesleev...item3caf1c8d21
The same seller offers a range of other sizes of firesleeve too, all sold in multiples of 100mm (4") length.
You might need to ask nicely about shipping to the US but he was helpful and communicative when I initially made my enquiries.
Steve Hutt
West Sussex, UK
