Old 06-08-2010, 07:35 AM
lostpilot28's Avatar
lostpilot28 lostpilot28 is offline
Hi Joe,
I am (wrongly or rightly) going to read into your replies and assume (I know, I know) that you are not going to call back Emagair out of principle. Your point is that you want a call back, not to have to call them back...again.
But, maybe they are really busy after just being gone for several days and are assuming that your problem isn't severe because you haven't called back. I don't know what the message that you left them states, but why don't you just call them again and explain your dissatisfaction. It's a win-win for both you that way.
I actually feel compelled to call them on your behalf and tell them to call you! ;-)
Sonny W
Boise, Idaho
RV-7A Flying!
Old 06-08-2010, 07:49 AM
N131RV N131RV is offline
Default Been calling every day.
Originally Posted by lostpilot28 View Post
Hi Joe,
False. I have called them more than once each day. I leave a message each time. I will be calling them again shortly today. Again I will leave a message.
Hangared since 11/23/2011, working on getting airborne again!
Joe Portman
N131RV - RV-7A, IO360A1B6, CS
Rebuilt as TD
Added dual MGL EFIS.
Airborne again at last! 2/21/2009
Elmendorf, TX (28TE)
baron (AT) baron (dot) com
Old 06-08-2010, 08:49 AM
ChiefPilot's Avatar
ChiefPilot ChiefPilot is offline
Originally Posted by N131RV View Post
My aircraft is part of my livelihood. Being down for multiple days with no sign of support is simply not acceptable. Maybe it would be for you. If so, more power to you. If I don't have some form of satisfaction by the end of tomorrow, PMAG will be history in my life. I need my airplane back in the air, not sitting on the ground waiting for a call that may or may not come this week.
It sounds like you'd be happiest if you ditched the PMAGs for slicks/bendix/etc. mags right now. Why wait?
Brad Benson, Maplewood MN.
RV-6A N164BL, Flying since Nov 2012!
If you're not making mistakes, you're probably not making anything
Old 06-08-2010, 09:02 AM
Default Good idea
Great idea. Thanks. Very insightful and helpful.
Emagair has contacted me. We are working toward a solution.
Joe Portman
Rebuilt as TD
Old 06-08-2010, 09:05 AM
Default Emagair has made contact.
Quite helpful, once contact is established. I will be doing (as stated before) the full troubleshooting guide. Emagair will be sending some parts to help the process.
Thanks to all who were helpful.
Joe Portman
Rebuilt as TD
Old 06-08-2010, 12:48 PM
cguarino cguarino is offline
Default I'll take them
If you don't like your Pmags, you can give them to me.
Charlie "T.Bear" Guarino
Springtown, TX
RV-4 Flying again with a fresh overhaul
Exempt but paid
Old 06-08-2010, 01:11 PM
Default I'll get right on that.
Thank you for the free, helpful advice. I'll take it under advisement.
Joe Portman
Rebuilt as TD
Old 06-08-2010, 01:44 PM
Default Just Joking
Actually, I called Brad for you. He had been sick. He agreed that he needs to be more accessible and said you had a valid gripe. We even talked about things like him getting a smartphone with email access. I hope you figure your problem out. I've been running P/Emags since 2005 and I love them. As you heard there were problems in the beginning. I know because I lived through some of them but now they seemed to have matured. Starts easier, runs better, saves gas, and now I think the are at least as reliable as a mag. Good luck and I'll still take them if you want to give them away.
Springtown, TX
Exempt but paid
Old 06-08-2010, 06:47 PM
Default More clues
Spent the day checking wires, plugs, connectors, etc. All four wires ohmed good. No shorts or opens. Connectors are made correctly and seated correctly.
The 6 pin and three pin connectors are firmly seated in the Pmag. The ground is good.
Checked pmag mount for tightness and retimed to TDC using the "puff" method.
All plugs good.
Symptoms:
Engines starts great, idles smooth, runs great up to about 2000 rpm.
Around 2200 rpm, the engine starts missing (a little).
At 2500 rpm, the Pmag begins cutting in and out badly, sometimes dropping 300 rpm before catching again. It's a scary sound.
Sometimes only stumbling a little. Occasionally backfiring. Cylinder temps and EGTs remain pretty even (no cold cylinders). Possibly (and it's not definitive) a small temperature drop on #3. So slight it's hard to really tell.
I really don't think it's a plug or wire at this point. All 8 plugs have been changed. All 4 wires have been checked. I'll have a complete new harness kit tomorrow and I'll remake all four plug wires just to be sure. If it is a plug wire, it's not like any plug wire symptom I have ever seen before.
It really feels like the coil is cutting in and out under load. Just a WAG.
Brad has been most helpful. Kudos.
Joe Portman
Rebuilt as TD
Old 06-08-2010, 06:54 PM
breister breister is offline
P-Mags (and other electronic ignitions) will fire a normal car timing light (induction pickup). Easiest thing in the world to have one guy run the throttle while another watches the timing behavior. Sounds like it is over-advancing.
