06-01-2010, 07:51 PM
Rubber Wing Root Seal
Interesting thing happened Sunday. My wife and I flew to an airshow in Janesville, WI, arriving around 1030 in the morning. We parked at a far corner of the airport, along with around 30 other transients just there for the airshow. We were bused over to the show side of the airport. After watching both the Canadian Snowbirds (my favorite flying team, please take comments to another thread...) and the US Thunderbirds, we took the bus back to our plane. Did the preflight, and we hopped in. While we waited in the plane for some other traffic to clear the parking area, a ground volunteer chatted with us from the right side of the plane, probably steadying himself on the wing.
At about 1000 agl, I started hearing some thumping on the right side. Hmmm. We looked around the perimeter of the slider canopy, but couldn't find anything to explain it. I figured the only thing it could be was either an airport cat that grabbed on or the rubber seal in the root fairing. We slowed down and diverted to a nearby airport (didn't see the need to circle back into the busy departures). The seal had come out up to about the wing spar. I removed the necessary screws, and put the seal back in. Since that same seal had been in for 9 years and 1200 hours (and removed/reinstalled at each annual), it seemed curious that it simply decided to come out. After putting it back in, I've flown about 3 hours with no issues.
I have to conclude that the guy who leaned over the wing somehow inadvertently pushed it down or somehow disrupted it.
Interesting coincidence: We didn't see anyone at the airport (Monroe, KEFT), until just before starting up. A guy came up, and said he had a 7 that had the root fairing seal come out on the first flight! I had already gone partway through the hot start procedure, so I wasn't able to talk.
Alex Peterson
RV6A N66AP 1700+ hours
KADC, Wadena, MN
06-01-2010, 08:01 PM
Good info on the seals. Did you use contact cement to keep them on? During my days at UAL we used "gorilla snot" AKA Pliobond to keep them in place.
I was at Janesville on Sunday. That was a GREAT airshow!
Tony Phillips
N524AP, RV 9 (tail wheel)
06-01-2010, 08:32 PM
No, nothing used to hold them in place. I might put a tiny screw through the rubber and through the fairing, just at the end.
Alex Peterson
KADC, Wadena, MN
06-01-2010, 09:07 PM
Amazing,
this *exact* thing happened to me on Saturday afternoon doing some local flying and aerobatics. Made for a bit of apprehension, since I did not know the cause until after landing.
Besided gorilla snot, any other suggestions on securing the wing root rubber seal?
Thx
06-02-2010, 12:41 AM
It happened to me once, so before a long cross country to OSH I put duct tape over the rubber so it wouldn't hapen on the trip. Instead, the leading edge of the duct tape formed and airscoop and the trailing edge formed a duck bill whoopy cushion sound maker. The result was loud buzzing sound just like a model airplane engine. After I landed it took a while to figure it all out. Later 3M contact cement worked much better.
John Adams
Seattle
RV7 600+hrs
Paid 12/2014
06-02-2010, 03:17 AM
It is more common than you might think
I installed mine tight and since no bonding or mechanical attachment was called out on the drawings I didn't add anything. This has been written up before but mine would come out and beat on the fuselage especially. This is a recursive process where you have to cut, fit, install platenuts for the closure strip and make the installation before you know it will work and you want to glue the thing together. Then you have to take it back off and glue it and let it cure before you reinstall it or the installation stress will pull the rubber away from the closure strip surface. I tried Pliobond but it isn't really adequate. That was my initial adhesive but at the end of the 2005 AirVenture Cup Race I pulled up after crossing the finish line at well over 200 mph and it blew out (200 mph seemed to be the magic number where mine would blow out) during the phase 1 test period. I finally installed the rubber seal strips on the aluminum closure strips with 3M yellow Weatherstrip adhesive following the proper procedure and that solved the problem. Now several years later the rubber looks like it was molded in place and I take take off the aluminum plates for annual inspections and the rubber requires no special attention at all.
Bob Axsom
06-02-2010, 04:54 AM
Bob Axsom
What Bob said! I just dabbed the 3M on in several spots between the rubber's "split" on the 7 so it stays stuck on the metal fairing when it's removed for inspection. I had the rubber strip come loose on my old Cherokee 140. It was the only time I've scared the wife while flying. She was not at all amused by the high speed drumming. On the 7 my seal fit tight enough I really struggled to install it during the build, yet the tail end started coming out during phase one. I caught it before it started beating on anything that time and reverted to the same fix I used on the Piper.
Joe Schneider
RV-7, IO-360, BA Hartzell, N847CR
Flying since 2008
06-02-2010, 10:19 AM
The similar arrangement...
...on my Grumman uses a single avex pop rivet at each end. I guess if the end doesn't lift out, the rest will be OK...
Gil Alexander
RV-6A N61GX - finally flying
Grumman Tiger N12GA - flying
06-02-2010, 10:19 PM
Use 3M 1300L...glue them to the fairing and they will never come off.  You might be able to use RTV as well but the 1300L is the way to go. Any A&P will know what I am talking about.
http://www.aircraftspruce.com/catalo...scotchgrip.php
06-02-2010, 10:29 PM
same on certified plane
Exact same problem happened 2X on the Beech Skipper, although at 90 mph instead of Bob's 200mph!. The original seal is 30 years old and essentially dryrotted to the point that there was nothing left to hold the glue. We had to spend $0.45 per inch for the correct seal (with 8130!) and then used the black 3M to hold it in place. Seems very solid now.
Dave Gribble VAF #232
Building RV-9A N149DG (slider, IO-320, IFR)
Restored and Flying Beech Super III N3698Q
Marion IA
Struggling with fiberglass
There is no sport equal to that which aviators enjoy while being carried through the air on great white wings." Wilbur Wright, 1905
