  #11
Old 05-25-2010, 06:35 PM
Deems Davis Deems Davis is offline
Originally Posted by vic syracuse View Post
Yes, I agree with the less than 9 theories. I try to keep it at nine and it doesn't want to stay there. I've only got 90 hours on it, but am about ready to see what it does at 8.
Vic
With 130 hours, this has been my experience, It holds much better @ 8-8.5 than above.
Deems Davis
RV10 N519PJ
http://deemsrv10.com/index.html
Old 05-25-2010, 07:40 PM
MichRV10 MichRV10 is offline
Mine likes 8 to 8.5 any more blows out the breather to the belly.
At 8 belly stays clean.
Old 05-26-2010, 07:54 AM
Super Moderator
Sounds good. I will let it slide down to 8.
Vic
Vic Syracuse
www.Baselegaviation.com
Old 05-26-2010, 02:58 PM
DocThrock DocThrock is offline
I use 8 to fill it at oil change. 9 if I'm going x country.
I can confirm the engine still runs with closer to only 1 quart in it... without roasting or seizing anything... for a few seconds anyway.....
Old 05-27-2010, 05:53 AM
RV10inOz's Avatar
RV10inOz RV10inOz is offline
Interesting Doc, we find 8 at oil change is finebetween 6.5 and 8 is what throws less out.
Maybe we are unlucky but above this you get a very oily plane.....no corrossion issues under there!
Old 05-27-2010, 10:22 AM
drfred drfred is offline
Mine usually hovers around 9 qts. I'll put in 10 at oil change. I'd rather clean the bottom than pull the engine.
240 hrs. And trying to figure out how to leave the office and put some more on.
Dr Fred.
515 FW.
