Go Back   VAF Forums > Avionics / Interiors / Fiberglass > Engine Monitors
Old 05-18-2010, 09:11 AM
nomocom's Avatar
nomocom nomocom is offline
Default MGL RDAC protection and mounting
I'm planning the install of MGL's engine module (RDAC) on the engine side of the firewall as suggested by the install manual. This allows the engine probes to terminate at the RDAC, then one wire leaves the RDAC and goes through the firewall to the EMS head. The manual suggests that in some installations an enclosure may be advisable for protection from water and oil. I find Lycomings to be a bit like old British engines, I always seem to be chasing oil leaks, so I'm thinking about providing some protection to the RDAC module from what seems like the inevitable oil misting.
On one end of the complexity and weight spectrum a simple Nomex slip cover. At the other end, a aluminum box with a couple 1/16th inch drain holes in the bottom so it can breathe a little. I'd also appreciate a bit of heat/fire protection a cover would offer, though if I'm on fire, I've got bigger problems than losing engine instruments
Thoughts? Experience?
Stan
1990 RV-3 (now apart, upgrades in the works)
1959 C172 O-360
Old 05-18-2010, 10:06 AM
GrayHawk's Avatar
GrayHawk GrayHawk is offline
There has been some discussion about RDAC enclosures on the Yahoo Stratomaster users group; but not sure the Yahoo search function works very well.
GrayHawk
My rebuild log: http://www.cherryfamily.net/bill/n63tx/rebuild/
Texas Hill Country Hangar For Sale: http://www.myspicewoodhangar.com/default.htm
Old 05-18-2010, 10:57 AM
Beancounter Beancounter is offline
Default RDAC mounting
Stan
I believe some have used a hinged plastic box, sort of like a household electrical panel. Perhaps some destructive testing is in order to determine the melting point.
Contact me by PM if you want to know how I mounted the RDAC behind the firewall.
See Chad Jensen's website for firewall forward mounting.
Matt
C-GVMK
RV9a Slow(ly) built
Flying as of July 2012
Old 05-19-2010, 06:20 AM
rwarre rwarre is offline
Default Mounted mine on fw
I made a metal box to go over the RDAC. Has been satisfactory so far.
Old 05-19-2010, 07:26 AM
lostpilot28's Avatar
lostpilot28 lostpilot28 is offline
Is your only reasononing that you want a smaller hole in your firewall for the single RDAC wire instead of a 1/2 inch hole for a dozen wires? I mounted my RDAC on the sub-panel under the windscreen. The wires passing through a larger hole wasn't really a concern. I wrapped them with high-temp rescue tape and put fire-barrier sealant on both sides of the hole. I only mention this because my engine compartment gets really oily...seems a light coat is on everything.
Sonny W
Boise, Idaho
RV-7A Flying!
Old 05-20-2010, 01:28 AM
Rainier Lamers Rainier Lamers is offline
We have seen anything from tupperware boxes to custom made enclosures costing many times the cost of an RDAC unit.
The units are not sealed and the terminals where you connect the wires are exposed. While we have had very good experiences with the terminals (these are German WAGO connectors of excellent quality and corrosion resistance), I can recall a single case of ingress of engine coolant caused by a leaking bottle mounted right above the RDAC (which, ahem, was ah, stupid ?).
Other than that we have never had a unit returned for repair that had anything to do with ingress of any liquid whatsoever.
Nevertheless, there's lots of wires so some form of protection is certainly not a bad idea. I don't however think there is much reason to go overboard with this unless your aircraft is going to be used in very unusual conditions.
Rainier
CEO MGL Avionics
Old 05-21-2010, 12:54 PM
nomocom's Avatar
Default engine side enclosure
Originally Posted by lostpilot28 View Post
Is your only reasoning that you want a smaller hole in your firewall for the single RDAC wire instead of a 1/2 inch hole for a dozen wires?
On my old 3, there is not easy access to the cabin side of the firewall, the forward deck is riveted in place, so work in this area is slow and uncomfortable. So, the 20+ wire terminations on the engine side is a big reason the RDAC is so attractive. I'll bring some wires forward, fuel sensor for example, that most the time stay behind the firewall, so I don't know that it will do much to reduce firewall penetrations.
Thanks everyone for all the helpful comments.
Stan
1959 C172 O-360
Old 05-21-2010, 04:36 PM
Brian Vickers Brian Vickers is offline
Default Mine is in the cowl cheek
Don't have all the answers... but this might work for you. I purchased an aluminum box from an electronics web store; 3? x 7? x 5.? I think it was about $8.00, plus shipping. Added some angle and nut plates to relocate the four screws that hold it closed. It's mounted inside the right cowl cheek, and is easy to open and service the RDAC. No scuffing knuckles reaching behind the engine in this location. Check out the space in the cowl cheeks.
Brian Vickers
Bainbridge Island, WA
RV4
Old 03-18-2013, 04:40 AM
I recently finished installing the MGL RDAC on the firewall. I received more than one "suggestion" to protect it from moisture. I concluded the most likely moisture would be from the front and above so I went with a 3/4 cover.
Old 11-15-2015, 02:04 PM
sblack sblack is offline
Do you guys just bolt the rdac right to the firewall or do you provide some vibration isolation?
Scott Black
VAF dues 2020
Instagram @sblack2154
