Go Back   VAF Forums > Regional Forums > Southeast
Old 05-04-2010, 01:15 PM
bkthomps bkthomps is offline
Default Trim tab Block
Anyone have the wood they used to bend/fold the trim tab and left elevator? I am having trouble without a bandsaw in creating an accurate block set to do this
Old 05-04-2010, 01:22 PM
caryr's Avatar
caryr caryr is offline
that little trim tab is painful
just cut the bendover tabs off and make 2 little ribs to replace them.
also, I would just go buy a Delta, aka cheapo, bandsaw. They are just tooo handy to do without.
heck they only cost $ 100
Cary Rhodes
Taylorsville, Georgia
N203CR
Van's RV-7
First Flight April 2004
Old 05-04-2010, 01:26 PM
N8RV's Avatar
N8RV N8RV is offline
I'd love to offer advice, but ... it was so long ago that I don't remember anymore how I did it!
Don McNamara
Peoria, AZ
Builder: RV-8 "Smokey"
Old 05-04-2010, 01:44 PM
where do you source the $100 bandsaw? I couldn't find any on amazon.com
Old 05-04-2010, 02:09 PM
esjacoby77 esjacoby77 is offline
Default check lowes
I bought a cheapo Ryobi bandsaw at Lowes. can't remember the exact price, but I'm sure it was under $150. No problems so far and I use it all the time. Make sure you buy a metal cutting blade...the blade it comes with will chew up your aluminum.
Old 05-04-2010, 03:25 PM
caryr's Avatar
I bought it as a return item at the Home Depot
I don't recall exactly the price, but it wasn't much over $100.
Cary Rhodes
N203CR
Van's RV-7
Old 05-04-2010, 03:33 PM
mackd's Avatar
mackd mackd is offline
Later (i.e. fuselage), you won't be sorry to have a bandsaw. It's worth it.
David Mack
RV-7 Fuselage In Progress
Fort Collins, CO
http://davidandemily.org/~mackd/rv/
Old 05-06-2010, 07:07 AM
pilotjt's Avatar
pilotjt pilotjt is offline
Default Get a bandsaw...
Yep, You will be very happy to have made a bandsaw purchase in the future. You can get one for $100@ home depot. Check Harbor Freight as well. Frankly, I consider it a "Must Have" tool for building an RV. Get a metal blade for $10, I went through 3 of them in the build.
*Tip-Use a wax candle as a lubricate on the blade before use.
Regards,
JT
RV8-N110JT
www.jtsrv8project.blogspot.com
KVPC
Old 06-01-2010, 10:47 AM
bought a bandsaw, still struggling with trimtab, ended up removing the tab on the elevator and now i'm trying to make a rib to put in there
